Cam Cover
Cam Cover
I just painted my vavle cover and decided to take off the cam cover (D16Y8, SOCH) and I was wondering is it ok to take it off or should I put it back on. I know Honda has it for a reason, im guessing to keep dirt, moisture etc off the belt. I see a lot of DOCH guys with there cams exposed but not many SOCH's.
Re: Cam Cover (Stylinhonda)
you don't want to expose your timing belt cover period. Something gets in there will either cut your belt or get pulled into the cam gears and slip the belt and you better hope your engine will stay in one peice.
Usally i see it because those guys do alot of motor work/ motor swaps so its left off, but its not recommended one screw/nut is all it takes
Re: Cam Cover (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">i've been running without one for over a year, nothing bad has happened yet</TD></TR></TABLE>
Yeah I know it's rarely that something will happen, but my friend was trying to clean his engine with a cover off engine running and the rag got pulled into the sprockets almost pulling his hand in there too. Timing skipped bent valves and engine was done. I've see squirls living inside the engine bay you just never know.
ditto. I haven't had one on in 3-4 years... If you're talking about just the upper cover, you're fine unless you're a clumsey guy that drops bolts and **** in random parts of your engine bay....
Littleredsi
01-24-2004 08:13 PM
