anybody tired 32 offset before?
anybody tried 32 offset before?
i'm looking at these very nice 15" wheels but the offset is 32. do you guys it's gonna rub on an EK with ~1.8 drop?
thnaks in advance.
Modified by atermizi at 11:30 PM 7/25/2004
thnaks in advance.
Re: anybody tired 32 offset before? (integlspwr2k)
search for the thread asking about +42mm offset wheels i run a 15x6.5 +32 wheel with 195-55-15 tires and only minimal rubing
Re: anybody tried 32 offset before? (atermizi)
It all depends on the width of the wheel. You could run a 0 offset if wheel was narrow enough. Also, the size(width and profile) of the tire will make a difference.
Stupid question: positive offset would only give you the issue of rubbing the outside of the fender/quarter panel, and not the inner portion, right? Or am I way off?
H-T Order of Merit
Re: (JRl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRl »</TD></TR><TR><TD CLASS="quote">If you have a larger number, you're more likely to rub the inside fenderwell. </TD></TR></TABLE>
Or you could rub the inside of the rim on the knuckle.
Re: (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">Or you could rub the inside of the rim on the knuckle.</TD></TR></TABLE>
yep so its better to get a higher offset its easier to roll you fenders then it is to shave down your knuckle etc..
Re: (integlspwr2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">
yep so its better to get a higher offset its easier to roll you fenders then it is to shave down your knuckle etc..</TD></TR></TABLE>
Gotcha, thanks
Gotcha, thanks
Re: (integlspwr2k)
you mean lower offset right?
lower (positive) offset: wheels stick out more
