Brake Kit For Si
Brake Kit For Si
I need to get some new brakes soon because my pads are worn down and the front-right rotor is cracked. I found a brake kit that comes with all 4 (OEM Spec) rotors and nippon braked pads for $255 Shipped. But it says that the kit is for 1992-2000 Civic Si. My car is a 1992 Civic DX HB. Will this kit fit my car? I've posted a link so you all can check it out if need so. Thanks again for your help guys.
http://www.theneednetwork.com/...e_kit/
Re: (electronb16si)
Well I do race quite a bit. Nothing to serious though. And I meet with about 8 or 9 other guys every other week. Will the stock specs be okay? My car is only a DX for right now, but i've done alot to it (exhaust/intake manifold, Intake, Cat-less Exhaust system) and I want to upgrade to a better clutch kit w/ lighter flywheel. With all this in mind can stock brakes handle this?
Re: Brake Kit For Si (EGB18)
get some brembo blanks with axxis ultimate pads. https://honda-tech.com/zerothread?id=831188 awesome prices.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGB18 »</TD></TR><TR><TD CLASS="quote">I need to get some new brakes soon because my pads are worn down and the front-right rotor is cracked. I found a brake kit that comes with all 4 (OEM Spec) rotors and nippon braked pads for $255 Shipped. But it says that the kit is for 1992-2000 Civic Si. My car is a 1992 Civic DX HB. Will this kit fit my car? I've posted a link so you all can check it out if need so. Thanks again for your help guys.
http://www.theneednetwork.com/...e_kit/</TD></TR></TABLE>
I wouldn't buy the kit simply because the vendor don't know what they are selling. The 92-95 civic si doesn't have the same brake setup as the 99-00 SI. different front rotors and pads.
Call up carbotech. honda-tech members get 10% off. http://www.carbotecheng.com
merlyn
12
12-28-2002 06:52 PM
