ECU Question. Urgent Help!!!
ECU Question. Urgent Help!!! Pictures inside...
what does RP18 stands for?
Would it makes any difference if it says just R18 ?
if so...RP18 and R18 are the same?
The reason I asked because I am doing an auto to manual conversion on my ecu, which is a JDM P30 Auto ECU [ yes, it is an automatic, I know]. Well, most people say to change the RP18 resistor from 2.4k olms to 1.4k olms and so does pgmfi.org. With curiosity, I've opened my ecu and found that there wasn't any RP18, but just found an R18 only with no letter "P". It is located on the little square box that can be detach and open away from the ecu. This is the row that it is in...R1, R2, R3 R17, R18, R19....I am wondering if they are the same so before I start to change the resistor f*&72 up a perfect ecu.
Any reference comments would be appreciated greatly....thanks..
the background of the resistor has a baby blue color. The stripes on it are orange, light red, yellow, dark blue, and dark brown....
Modified by SkyLinER at 5:36 AM 7/26/2004
Re: ECU Question. Urgent Help!!! (SkyLinER)
don't worry about lowering the resistance, simply remove the RP17 completly. this will remove the check engine light and other auto related issues.
Re: ECU Question. Urgent Help!!! (eg6ajk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk »</TD></TR><TR><TD CLASS="quote">don't worry about lowering the resistance, simply remove the RP17 completly. this will remove the check engine light and other auto related issues.
Hopefully he can find it. It is only .25" from RP18. I sent a picture to him via IM. He called me a liar because RP18 isn't on the back side of the PCB....
Re: ECU Question. Urgent Help!!! (Jim Truett)
These picture are credited to Jim Truett...I'm just borrowing...thanks..jim.
ok...so I just have to remove RP17 as shown heremy JDM P30 Automatic ECu and i'm set to go right ?....
Btothe3rdDegree
06-27-2004 06:51 PM
