Ground controls
Old 08-18-2004, 09:40 PM
spoonef's Avatar
Default Ground controls
I bought some used gcs two days ago with ek struts and i need help identifying the spring rates
Rear 180.64.44 Front 200.64.58.What would you suggest i put up front and back and back of my eg and are koni yellows a direct bolt-on?
spoonef is offline
Old 08-18-2004, 10:16 PM
SD350z's Avatar
Default Re: Ground controls (spoonef)
i'm guessing you're talking about the sleeve coilovers...if i remember correctly, there's some special GCs for the konis.... check http://www.prostreetonline.com and check part numbers. the ones for koni yellows were like 330 or something. hope that helps
SD350z is offline
Old 08-18-2004, 11:08 PM
Default Re: Ground controls (SD350z)
Yep, Ground Control's are different for Koni's.
KStuned is offline
Old 08-19-2004, 09:56 AM
spoonef's Avatar
Default Re: Ground controls (Hondaddict)
Is there any modifications involved when fitting koni yellows onto gcs?
spoonef is offline
Old 08-19-2004, 12:13 PM
spoonef's Avatar
bump
spoonef is offline
Old 08-19-2004, 05:10 PM
spoonef's Avatar
bump
spoonef is offline
Old 08-19-2004, 07:38 PM
ek9800's Avatar
you hav to get a certian set of GC for Konis
ek9800 is offline
Old 08-19-2004, 07:48 PM
EK k kay's Avatar
Default Re: Ground controls (jdm98hb)
So you're not selling them anymore?
EK k kay is offline
Old 08-19-2004, 08:08 PM
Default Re: Ground controls (chowmien)
I think you need to call them http://www.ground-control.com/
there answer I believe will be better than the ones here IT they can sell you an adapter or exchange ect
otherwise I believe you can mod the konis
but contact them first
FF lotus is offline
Old 08-19-2004, 08:33 PM
Malakai's Avatar
stiffer springs in the front
Malakai is offline
Trung Nguyen
12-18-2011 02:14 AM
lilo_goki
16
03-10-2008 10:16 AM
trdae86
06-05-2006 10:19 AM
igone916
13
02-27-2004 01:01 AM
Quick Reply: Ground controls
  • Ask a Question
Question Title:
Description:
