Soft clutch pedal with ACT XTSS
Old 08-18-2004, 09:46 PM
Pandahatch's Avatar
Default Soft clutch pedal with ACT XTSS *PICS*
I started to put my setup back in the car tonight and I got the tranny on and everything went on alright. I used an ACT XTSS clutch kit. I put the clutch lines and slave cylinder on and the slave cylinder dust cover was filled with fluid. The pedal was also on the floor. Could this be a bad slave cylinder? Anyway, I pulled the pedal back up and bled the lines and go to feel the pedal. The pedal would go down about halfway before I felt any pressure and it didn't feel right either. I had an HDSS in my other car and it felt heavy as ****, this doesn't feel at all like it and it's a heavier pressure plate. I look under the dash to see liquid coming out of the clutch master cylinder, I'm guessing this is shot too. Would a leaking master cylinder make the clutch feel too soft. It was moving the slave cylinder fine, just doesn't feel right.
Modified by PandaHatch at 7:57 AM 8/19/2004
Pandahatch is offline
Old 08-18-2004, 10:09 PM
nocturnaldragon's Avatar
Default Re: Soft clutch pedal with ACT XTSS (PandaHatch)
Id say its a bad master cylinder. Replace that bleed everything and see where your at. The clutch should be very stiff at first and gradually get easier to use and it losens up a bit (Few hundred miles) but it should still be almost twice as stiff as your stock clutch. I have the same clutch in my car and it is defiently harder to push and hold down the clutch then the stock so......
nocturnaldragon is offline
Old 08-18-2004, 10:36 PM
Pandahatch's Avatar
I just pulled off the cylinder, took about 10 minutes or so, I'll post a few pics of the results.
Old 08-18-2004, 10:56 PM
Pandahatch's Avatar
Default Re: (PandaHatch)
Here are the pics of the master cylinder
Old 08-18-2004, 11:52 PM
Pandahatch's Avatar
TTT
Old 08-19-2004, 12:03 AM
CivicSiRX's Avatar
dood that mc is toast. get a new one. i replaced mines, made a world of a difference as in pedal feel for my clutch.
CivicSiRX is offline
Old 08-19-2004, 12:04 AM
Pandahatch's Avatar
That's what I wanted to hear. I was gonna replace it anyways after noticing it leaking. Thanks.
Old 08-19-2004, 02:56 AM
StreetProjectz's Avatar
i had the same problem. replaced the clutch master cyl. and it was fine.
StreetProjectz is offline
Old 08-19-2004, 05:31 AM
EVILhatch's Avatar
whenever you replace your clutch its always a good idea to get atleast a new master if not both master and slave cylinders...
EVILhatch is offline
Old 08-19-2004, 06:44 AM
vtec69's Avatar
Default Re: Soft clutch pedal with ACT XTSS *PICS* (PandaHatch)
the MC must be shot
vtec69 is offline
Old 08-23-2004, 11:18 PM
Default Re: (EVILhatch)
Why would you want to replace those? When you replace brake pads you dont replace your capilers, and they put out a lot more pressure and deal with a lot more stress then the clutch hydros would anyday.......
Just curious with your reasoning behind this, not trying to be an *** like i normally am on here.
Old 08-24-2004, 12:09 AM
senpai's Avatar
Default Re: (nocternaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon &raquo;</TD></TR><TR><TD CLASS="quote">Why would you want to replace those? When you replace brake pads you dont replace your capilers, and they put out a lot more pressure and deal with a lot more stress then the clutch hydros would anyday.......
Just curious with your reasoning behind this, not trying to be an *** like i normally am on here. </TD></TR></TABLE>
HaHa, you're right though. Replacing both master and slave cylinders? Why stop there? Get a new transmission too
senpai is offline
Old 08-24-2004, 07:48 AM
hayabusa160's Avatar
Default Re: (maztur)
oh crap mines look like that too
i need a new one too
hayabusa160 is offline
gooblinn258
01-18-2014 05:02 PM
hbhonda
11
11-28-2009 11:56 AM
hYbRiD EeEkAy
08-07-2008 11:27 AM
RaceMyGhost
12-26-2005 09:51 PM
tremor86
06-26-2003 02:43 PM
Quick Reply: Soft clutch pedal with ACT XTSS
  • Ask a Question
Question Title:
Description:
