SRS light on! any help
well i installed a ctr steering wheel on my friends 99 si, and afterwards the srs comes on when the car starts and stays on, any suggestions?
thanks in advance
thanks in advance
Re: SRS light on! any help (vtec 5 6 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec 5 6 2 »</TD></TR><TR><TD CLASS="quote">well i installed a ctr steering wheel on my friends 99 si, and afterwards the srs comes on when the car starts and stays on, any suggestions?
Did you reinstall the airbag?
Re: SRS light on! any help (SirRevvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs »</TD></TR><TR><TD CLASS="quote">just a guess but maybe try resetting your comp. i.e. unplug the battery for 10 min</TD></TR></TABLE>
That's not a vey good guess, it wont work.
Re: SRS light on! any help (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca »</TD></TR><TR><TD CLASS="quote">
Did you reinstall the airbag?</TD></TR></TABLE>
yes
yes
Re: SRS light on! any help (95eghatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95eghatch »</TD></TR><TR><TD CLASS="quote">try unplugging your ecu. worked forme</TD></TR></TABLE>
Again, I doubt that will work.
yes</TD></TR></TABLE>
Ok, the procedure to clear srs codes using the MES connector is posted around here somewhere. Maybe a quick search will find it?
Ok, the procedure to clear srs codes using the MES connector is posted around here somewhere. Maybe a quick search will find it?</TD></TR></TABLE>
good deal, thanks !
good deal, thanks !
92ehatch
19
05-08-2007 08:57 PM
tbcmorris
04-03-2004 09:47 AM
