Swap start-up problems.....
Old 08-19-2004, 09:00 AM
spyderracing's Avatar
Default Swap start-up problems.....
Ok so I'm here at the end of my first swap (jdm d15b into a VX easy right?) and got everything hooked up, double checked all the hoses and clips were in the right place (I have a few extra clips here and there, but can't find a place for them to plug into). So I go to start it, and it cranks like it want's to start, but then I here a chugging or a knocking kind of noise. I pulled the spark plugs because I forgot to check those, so maybe that could be it. They were fouled with oil so I put new ones in a still it won't start. When I pulled the wire from the number 4 plug..... smoke came out of the valve cover.... not a lot, but little whisps . Anyone know what to do? What the root of my problems may be?
I have yet to bleed my clutch so I just let it sit on the floor to try and start it. Anyone have ANY ideas?
spyderracing is offline
Old 08-19-2004, 09:48 AM
Default Re: Swap start-up problems..... (spyderracing32)
Up, I just pulled the new spark plugs, and they're a bit wet around the threads but not the tip.... anyone have any ideas?
Old 10-24-2004, 05:30 PM
bleedblue94's Avatar
are you getting spark
bleedblue94 is offline
Old 10-24-2004, 05:32 PM
JDMlyfestyle's Avatar
check all of your grounds.
Tranny > chassis
Batter > Chassis
Wiring Harness > thermostat housing
Head> chassis
JDMlyfestyle is offline
Mindgamez
07-20-2009 09:02 AM
slk08
05-20-2009 11:09 AM
jakscivic
01-13-2007 12:17 PM
cb7joba
01-01-2007 11:11 AM
AndyD
03-19-2006 01:19 PM
Quick Reply: Swap start-up problems.....
  • Ask a Question
Question Title:
Description:
