how hot should your your engine be?
My block is 250+ valve cover is 215+ and exhaust manifold is close to 600. Sound about right? or am i over heating?
Re: how hot should your your engine be? (civic_speed99)
My temp gauge never goes over 3/8. Sometimes I think it's broken. Once the car's all warmed up the needle goes up to 3/8 or real close to the 1/2 point and just stays there til I turn the car off.
Re: how hot should your your engine be? (chowmien)
I have the same exact problem! How doy ou fix it? I may be having over heating problems so thats why I asked.
Re: how hot should your your engine be? (Poopie)
Not sure if it is even a problem. The valve cover does get very very hot after I drive around for like 20 mins (after warmed up). The headers get even hotter (duh).
what did you use to measure the temp of the engine?
also what was the ambient temp?
You need this to figure out temp. I think your meter was messed up because that's a pretty high figure.
Re: how hot should your your engine be? (hond77)
I have a raytech laser infared temp gauge. Its pretty damrn accurate. Ambient temp was probably int he mid 70's. I have a whirring noise so it might be a faulty water pump. Will I have to replace the whole unit?
halocore
09-02-2008 01:59 PM
electric-boost
12-11-2006 08:37 PM
