ac lines please help
my friend has a 94 ex civic with a gsr swap and i would like to know will integra ac lines work in the civic if i use a ls ac compressor or a gsr compressor
Re: ac lines please help (rkn527)
Which AC lines?
If it's the AC lines that run from the firewall/evaporator box down the left side towards the front running under the airbox, then I doubt it. I had to replace the AC lines on both a DC and an EH before. Both part numbers were different and they both just looked different. Anyway, if you wanna experiment with a new project, go for it and let us know. Good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkn527 »</TD></TR><TR><TD CLASS="quote">my friend has a 94 ex civic with a gsr swap and i would like to know will integra ac lines work in the civic if i use a ls ac compressor or a gsr compressor</TD></TR></TABLE>
what a/c bracket does your friend have. i also have a gsr in my 95 civic ex. the gsr a/c compressor is in place but the civic ac lines does not connect to a gsr compressor.
it had a gsr compressor on it but the lines from the civic wont work. could i use some teg lines then the ac lines will work
coot_er
07-22-2004 01:59 PM
