whats the dif between a B16b and a B16a?????????????
Im trying to get all the info I can on a swap for my Z1 EG can any one tell me the difference between a B16B motor and B16A motor?
1 Post
Re: whats the dif between a B16b and a B16a????????????? (djryan380)
B16B came in the CTR in Japan. It's a 180 (or 185) HP motor, nearly the same as a B16A (160 HP USDM), but with higher compression, and slightly different valvetrain (lighter components). Other than that, I'm not sure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djryan380 »</TD></TR><TR><TD CLASS="quote">Is it hard to get B16B in the US? What kind of dow im I looking at drop'n?</TD></TR></TABLE>
About $3k worth of 'dough'.
hmm.. if you're going to spend money to swap the b16b.. might as well get the b18c type r motor... you're not paying THAT much difference between the two.. where you get more torque with the b18 because of the increased displacement.....
Come on I sure hope that you arn't doing the swap. A b16b is a ctr and it is totally different from a B16a the cams, valve springs, retainers, crank its all different even the vtec soliniods are different and an ITR uses a CTR head to get rid of the secondairy butterflys dued dont waste ur money on a CTR or A ITR just buy an OBD 1 gsr and take the thousand dollars u save and buy yourself skunk 2 cams and a zex programble nitrous kit you will eat up any ITR or CTR out there
1 Post
Re: (delsol_gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsol_gsr »</TD></TR><TR><TD CLASS="quote"> an ITR uses a CTR head to get rid of the secondairy butterflys </TD></TR></TABLE>
That's the i/m, not the head
Re: (delsol_gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsol_gsr »</TD></TR><TR><TD CLASS="quote">Come on I sure hope that you arn't doing the swap. A b16b is a ctr and it is totally different from a B16a the cams, valve springs, retainers, crank its all different even the vtec soliniods are different and an ITR uses a CTR head to get rid of the secondairy butterflys dued dont waste ur money on a CTR or A ITR just buy an OBD 1 gsr and take the thousand dollars u save and buy yourself skunk 2 cams and a zex programble nitrous kit you will eat up any ITR or CTR out there </TD></TR></TABLE>
werd homeboy. beleive dis newbie right hur. he's be's speaking the trooof
drag raysah fo life
drag raysah fo life
Re: (b cruz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b cruz »</TD></TR><TR><TD CLASS="quote">
drag raysah fo life </TD></TR></TABLE>
come again?
come again?
Re: (Milano98teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Milano98teg »</TD></TR><TR><TD CLASS="quote">
come again? </TD></TR></TABLE>
:skeet:
:skeet:
Re: (delsol_gsr)
Where the hell you come man. 2 posts and both of them are bullshit posts.
be professional
Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL »</TD></TR><TR><TD CLASS="quote">and YES it does have 185Hp</TD></TR></TABLE>
It is rated at 183hp (185ps), but the B16B actually makes more power than that. Honda underrated it.
The B16B doesnt stop making power until after its 8400 RPM redline. Rev it up near its 9000 RPM fuel cut and it will be cranking out close to 200hp.
Risky Business
Re: (Targa250R)
Okay this retard fest must come to an end.
https://honda-tech.com/zerothread?id=406799
https://honda-tech.com/zerothread?id=393236
https://honda-tech.com/zerothread?id=373605
E. Honda
75
01-24-2003 01:42 PM
