Temp, Oil Pressure, Etc guages universal?
I've been searching around and can't quite get a clear answer. My water temp guage is busted, so my real question is, will any water temp guage work in its place? On the same level, do all oil pressure, fuel guages, electronic speedo's, tachs, etc use the same signal levels as the OEM parts?
Re: (jdmctreg93)
On the cluster guages, most have a +, ground, and data wire. Does this go for aftermarket guages as well? And if it does, does the signal on the data wire get interpreted the same by universal aftermarket guages as it does by the OEM ones? I'm guessing it does, but want to be sure before I throw money around.
