Noob wants to know suspension swap options for EG coupe?
What are my options for a low cost suspension upgrade for front and rear? I've heard that I can convert the rear to disc from an Integra. Which year Integra, and what parts would I need?
Any other recommendations would help.
Thx.
Thx.
Re: Noob wants to know suspension swap options for EG coupe? (supdawg2)
I know for sure that '94-up integra rear brakes will fit.
Also rear discs from a '92-'95 civic si will work.
Get the entire rear trailing arm, brake lines and e-brake cables.
Re: Noob wants to know suspension swap options for EG coupe? (Slopoke)
I have rear disks from a 2000 Civic Si on my EG (it's for sale, see sig), you just have to use 94+ Integra lower control arms. Other than that they bolt right up!
Re: Noob wants to know suspension swap options for EG coupe? (Amkread)
But I thought with the 90-93 you couldn't use the LCA? With the 94+ teggy you can use the LCA with the 92-95 civic correct?
[QUOTE=Slopoke]
im not sure about fitment but even newer si rear discs, i would stick w/civic breaks as oposed to integra because of the bult patern, you wont want different bult pattern on fornt and back it will b hard 2 shop for rims,
older integras have the same tho, not sure what year integras and not completly sure of it.
Re: Noob wants to know suspension swap options for EG coupe? (Honda24C)
All Integra bolt patterns are the same, except for the type R because its 5 lug.
86-01 teggy is 4x100
80-96 civic is 4x100
Civic SI hatchback has the 5x114
I believe the type R is 5x114?
Bolt pattern info came from these websites:
http://www.discountedwheelware...e.cfm
EDIT: I'm actually pretty sure ALL years of civics have the same bolt pattern, unless its a special model like the SI or the Type R. Even then I think that most yeas of the SI had the same bolt pattern, not really sure though.
Modified by Ajax at 3:56 PM 8/19/2004
unknown0001
14
08-30-2004 09:00 PM
