Oil all over:(
Oil all over:(
Yesterday i checked my oil and there was none....the motor wasnt knocking or anything so i put the 4 quarts in it and today after i get home from driving it froms chool there is oil all over the place....the motor runs and sounds fine, but where could the oil be coming from:-/
Re: Oil all over:( (hondaracing1)
Clean your engine/ engine bay really good and make sure you have enough oil in it. Then start it up and look for a leak.
If you cant see any oil coming from anyewhere.
Take the car for a romp around the block. That way it will give the oil enough time to squirt out but not enough time to get everywhere so you cant tell where its coming from.
Then look. And fix the problem.
Modified by _BEN_ at 12:26 PM 8/19/2004
drop ur oil pan and check the gasket, make sure ur oil filter is tight, check ur valvecover gasket, worst case is that ur headgasket is shot... it should be something that i listed tho
Re: Oil all over:( (_BEN_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _BEN_ »</TD></TR><TR><TD CLASS="quote">Clean your engine/ engine bay really good and make sure you have enough oil in it. Then start it up and look for a leak. </TD></TR></TABLE>
TurbothisLS
02-11-2002 01:00 PM
