Fender rub all around on 205/50/16 16x7 40mm offset
I just picked these wheels/tires up and im rubin like crazy....i gott about 1-2 finger gap all around, id figure id be able to tuck these tires...
if i get my fenders rolled, any chance i could tuck in the rear?
If i get 205/40/16 is it possible the tires wouldnt fold out over the wheel as much?
Re: Fender rub all around on 205/50/16 16x7 40mm offset (JD95hatch)
your best bet is to go down one or two... like 205/45 or even 205/40's would be better. just dont slam into potholes fast....that **** ***** you up haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JD95hatch »</TD></TR><TR><TD CLASS="quote">If i get 205/40/16 is it possible the tires wouldnt fold out over the wheel as much?</TD></TR></TABLE>
The 205/40/16 tire would just have a shorter sidewall. You would have to go with 195/xx/16 if you don't want the tire to "Fold out" as much.
Re: Fender rub all around on 205/50/16 16x7 40mm offset (electronb16si)
true...i just figured that the sidewall was so big that it flared out a little....im gonna try and find some cheap 205/40s and see if that helps any...
is this a normal problem....?
All Motor Mentor
1 Post
Re: Fender rub all around on 205/50/16 16x7 40mm offset (Wild0ne21)
The tire rubs because it's to tall (50 series) for a 16" wheel on a Honda. A 205/50 is ok on a 15"wheel but you shouldn't go above a (205) 45 series on a 16" wheel, (205) 40 series on a 17" and (215) 35 series on an 18".
Also if your car still has those factory rubber inner lip covers on it, pull them off as the tires are prone to rubbing on them. Removing them will give you some aditional clearance.
Re: Fender rub all around on 205/50/16 16x7 40mm offset (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">
Also if your car still has those factory rubber inner lip covers on it, pull them off as the tires are prone to rubbing on them. Removing them will give you some aditional clearance.</TD></TR></TABLE>
removed them a long time ago to help prevent rust...
Ill be lookin to sell the tires soon once i get some 204/40s but im about to leave for college in 3 days so most likely wont be for another 2-3 weeks.
thanks guys!
thanks guys!
CLICC916
02-13-2002 01:38 PM
