Del Sol Gas Mileage Question...
Old 08-18-2004, 09:36 PM
Ecskater1313's Avatar
Default Del Sol Gas Mileage Question
I have a 93 del sol SI and i was wonder why my car doesnt do over 200 Miles on a full tank help!!! im always on empty by 160 or 170. but when im on the free way its does about 250 ????? Help anyone
Modified by Ecskater1313 at 3:12 AM 8/20/2004
Ecskater1313 is offline
Old 08-18-2004, 09:44 PM
o d i e e's Avatar
Default Re: Im just curious? (Ecskater1313)
thats city driving for ya !
o d i e e is offline
Old 08-18-2004, 09:50 PM
Soccerking3000's Avatar
Default Re: Im just curious? (Uphill.Specialist)
well you have the d16z6 (if its the stock motor), is the light coming on sayin you need to get gas, cause sometimes it goes on with 2-3 gallons left in the tank. Try this get a full tank and then get one of the gas cans and put a few gallons in that, drive around untill your car starts having serious issues with gas and see how many miles you've gotten, the extra gas can is there so you dont get stranded, i found on ym car that i ahd around 2 gallons left when the light turned on which ended up being around 60-70 miles
Soccerking3000 is offline
Fugeeu's Avatar
It's da vtec yo!!!
Fugeeu is offline
Old 08-18-2004, 10:26 PM
nocturnaldragon's Avatar
Default Re: Im just curious? (CivicDX95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicDX95 &raquo;</TD></TR><TR><TD CLASS="quote">It's da vtec yo!!!</TD></TR></TABLE>
Im really getting tired of a$$holes making comments like this to jack up there post counts its pointless and just pushes dead threads to the top when theve been long done and over with.
Anyhow the 93's dident come with the Idiot light for the low fuel to my knowledge i think they added that 2 yrs later. But i would sagest this, When you go for a fill up rememeber your tank hold about if not exacltly 10 gallons for the sake of arguement. So when you fill up make a note of how much fuel your putting in your tank 8,9,10 gallons and make a estimate mpg bassed on that. My car averages about ohhh 25mpg city and i do in no way shape or form baby it i drive it HARD as hell like i stole the bitch. So you should get about the same if not better. Keep in mind tho mine is a stick and that makes a huge differance. Now after doing all that and your getting crappy gas millage think about doing a tune up ie. New plugs, check your wires, clean up the dizzy or replace the cap. The skills need to do an tune up along those lines is negligable, if you can turn a wrench and screwdriver you can do it no prop. Just make sure you have a long enough extension and spark plug socket (MAkes it soooo much easier! - Apply antisieze to the new plugs youll be thankfull you did next time!!!!0.
Hope that helped!
nocturnaldragon is offline
Old 08-18-2004, 10:35 PM
rentacop's Avatar
Default Re: Im just curious? (nocternaldragon)
I get 400 per tank or more :]
rentacop is offline
Old 08-19-2004, 10:28 AM
hondainspired's Avatar
Default Re: Im just curious? (rentacop)
i'm looking at... 300 miles per tank with LOTS OF ****** AROUND... city driving... (same z6 as in the SI delsol)
hondainspired is offline
Old 08-19-2004, 04:48 PM
IS there something i should check ?? so i can conserve more gas????
Old 08-19-2004, 05:22 PM
sohcvtec1995's Avatar
any CELS? if no how far up in revs do you go befor shifting gears. also as the motor gets older the gas mileage will go down. Do a tune up on it it should help out.
sohcvtec1995 is offline
Old 08-19-2004, 05:54 PM
murmur9's Avatar
Default Re: Im just curious? (sohcvtec1995)
How long has it been since you changed your spark plugs and wires....fuel filter....air filter...cleaned your injectors...blah blah...
murmur9 is offline
Old 08-19-2004, 06:02 PM
I love doing tune ups.... there my favorite (cause there so easy).. i have to do a fuel filter soon...
Old 08-19-2004, 06:12 PM
be professional
Targa250R's Avatar
How about you use the standard unit for measuring fuel economy (miles per gallon) instead of this crapshoot "miles per tank" figure?
Targa250R is offline
Old 08-19-2004, 06:13 PM
Default Re: Del Sol Gas Mileage Question (Ecskater1313)
Well i just change my spark plugs distributor cap and rotor. xcept my wires
Old 08-19-2004, 06:21 PM
You might want to check the fuel filter as well, if it hasn't been changed in a while, go ahead and put in a new one.
JMod is offline
Old 08-19-2004, 06:48 PM
JamesQ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon &raquo;</TD></TR><TR><TD CLASS="quote">Im really getting tired of a$$holes making comments like this to jack up there post counts its pointless and just pushes dead threads to the top when theve been long done and over with. </TD></TR></TABLE>
to me, thats OWNED
JamesQ is offline
Old 08-20-2004, 01:01 AM
Stoich EG2's Avatar
Default Re: Im just curious? (JamesQ)
i used to have the same problem. around 220 miles would do it for me. my friends suggested SEA FOAM and fuel injector cleaners. i did the fuel injector cleaners and it worked. another thing you should look for is your tire pressure and alignment of your tires. that also makes a difference. when my car was slammed, i got crappy gas mileage but after i raised it a good 2 inches, my gas mileage went up! i did a little comparison with 87 octane rating gas and 91 octane and 91 SEEMS like it works better for my gas mileage but that compensates for the cost.
Stoich EG2 is offline
Old 08-20-2004, 08:29 AM
Del Sol SiR's Avatar
Default Re: Im just curious? (Soccerking3000)
93' Del Sol's didn't come with Low Fuel indicator light
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">is the light coming on sayin you need to get gas, cause sometimes it goes on with 2-3 gallons left in the tank.</TD></TR></TABLE>
Do a tune up, like some peeps are saying.
*1993 Honda Del Sol Si (Specs)
1.6L SOHC VTEC - 125 bhp @ 6600 rpm
106 ft-lb @5200 rpm
Redline: 7200 rpm
EPA mpg: (City/Highway) 29/35
0-60 : 8.2
0-80 : 14.8
0-100 : 26.5
1/4 Mile : 16.6 sec @ 84.9 mph
Top speed 122 mph
Braking : (60-0mph) 126 ft
Lateral Acceleration : 0.84 G
Wheels/Tires : 14" alloy w/185/60 R14 82H
Curb Weight : 2,414 lb
Del Sol SiR is offline
Old 08-20-2004, 09:04 AM
well **** i like those specs a lil bit actualy.. my coupe weighs more then the sol i take it though
Old 08-20-2004, 02:47 PM
be professional
Targa250R's Avatar
Default Re: (hondainspired)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondainspired &raquo;</TD></TR><TR><TD CLASS="quote">well **** i like those specs a lil bit actualy.. my coupe weighs more then the sol i take it though</TD></TR></TABLE>
Not really. Your coupe is lighter by almost 25 lbs.
Old 08-20-2004, 06:51 PM
Default Re: (Targa250R)
Thanks!
Old 08-22-2004, 02:47 AM
Old 08-22-2004, 03:24 AM
jerbear!'s Avatar
i got a sohc sol too and yea i been having the same problems. i used to go from 430s on a full tank to low 200s. then i just did a basic tuneup. spark plugs/wires caps n rotor, oil change, and fuel filter and now im good again
jerbear! is offline
Old 08-22-2004, 09:02 AM
be professional
Targa250R's Avatar
Default Re: (DelSolSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolSiR &raquo;</TD></TR><TR><TD CLASS="quote">Gross Vehicle Weight Rating</TD></TR></TABLE>
GVWR is not the same thing as curb weight.
The GVWR is the weight of the car when fully loaded to capacity.
An empty Civic does not weigh 3,000+ lbs, that is insane. The curb weight of a '93 Civic EX coupe is 2,390 lbs. The curb weight of a '94-95 Civic EX coupe is 2,443 lbs.
https://honda-tech.com/zero...56615
Old 08-22-2004, 12:04 PM
Ah, got me... thanks for the info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zero...56615</TD></TR></TABLE>
Old 08-22-2004, 04:09 PM
DelSolSi93's Avatar
Ive found that on my del sol any decrease in gas mileage is usually an indicator that i need new plugs, an oil change, fuel filter, etc I would try what everyone else has suggested and do a tune up, also use 91 fuel I get awesome mileage by using that octane, Im getting 385 city and 425 highway to a tank of 10.3 gallons
DelSolSi93 is offline
Quick Reply: Del Sol Gas Mileage Question...
  • Ask a Question
Question Title:
Description:
