b16 idling rough
Old 10-15-2004, 06:59 PM
mrnice1058's Avatar
Default b16 idling rough
ok i finally got my b16 in and running it is in a 97 civic and it is running really rough the other problem i am having is it will not stay on unless i hold the gas petal down is there anything i can check please let me know thanks guys..
the civic is a 97 lx and the ecu is a chipped p28 if that is needed thanks guys
Modified by mrnice1058 at 1:15 AM 10/16/2004
Old 10-16-2004, 09:45 AM
mrnice1058's Avatar
Default Re: b16 idling rough (mrnice1058)
man no one can help me out?
Old 10-16-2004, 09:50 AM
dohcdelsol93's Avatar
have you checked timing, is it throwing any cel's? is compression good, are you getting plenty of flow from all of the fuel injectors? Spark on all cyl.?
Old 10-16-2004, 06:43 PM
billyhoe's Avatar
Is your IAC plugged up?
Old 10-16-2004, 08:35 PM
mrnice1058's Avatar
Default Re: b16 idling rough (billyhoe)
well compression is good i have flow how can i check if the injectors are good? i am getting spark from all cylinders my timing is perfect not eve off by a tooth. the IAC is plugged it now the check engine light is on but i don't know how to do the CEL check i see the green plug but what do i do something about putting a pin in there or something can someone tell me how to do that thanks
Old 10-16-2004, 08:37 PM
civictildeath's Avatar
what is your timing at?? should be 16 degrees before tdc
Old 10-16-2004, 08:41 PM
billyhoe's Avatar
on the green plug you will see two connectors, a 3-wire and a 2-wire. Pull the 2-wire plug out of the green holder and place a paperclip or speakerwire or whatever just as long as the two wires jumped. Turn key into on position, CEL blinks, count, and get code.
Old 10-16-2004, 08:51 PM
mrnice1058's Avatar
yeah your talking about the dizzy timing correct? yes it is on or just about 16 degrees. so i don't know i will check that cel tomorrow and see what it says
Old 10-16-2004, 08:54 PM
mrnice1058's Avatar
o yeah i forgot to ask can i do it being that my civic is obd2a and my ecu is obd1? will it bling for me?
Old 10-16-2004, 10:24 PM
MaD V-TaK's Avatar
to check the the cel you have to put somthing in it like billyhoe said but when you turn your key on dont start it just turn the key on and the light will blink once but after that one blink long blinks count as 10 and short blinks are 1 i just thought i would clear that up a lil bit
Old 10-16-2004, 10:28 PM
mrnice1058's Avatar
Default Re: b16 idling rough (MaD V-TaK)
hey thanks alot man i needed to know that but i was still wondering about if i can do it on my obd2 car because i am using an obd1 ecu it should still work right? or do i need to get one of those code readers? thanks guys
Old 10-16-2004, 10:37 PM
billyhoe's Avatar
yep it depends on your ECU
Old 10-16-2004, 10:40 PM
mrnice1058's Avatar
chipped p28 is the ecu i am running
Old 10-17-2004, 04:23 PM
mugencivic99's Avatar
hey man i have a p-28 chiped in my 99ex with a ls vtec using a 99 head from my b16a2// it all works fine the only i could think is if it is not timing then maybe u have a vaccum leak or a bad fuel regulator that is no keeping enough fuel.. it happen to a friend of mine,, maybe that will help.. but far as the ecu it works the same just dose not read intake sensor or second o2.. or the crank angle sensor,, plus to me it makes it run alot better i have the mugen chip in mine,,
Old 10-17-2004, 04:59 PM
menkio's Avatar
Default Re: b16 idling rough (mugencivic99)
guess he does'nt want his car fixed.. takes all of what 5 min to check the cel
Old 10-18-2004, 04:25 AM
mrnice1058's Avatar
Default Re: b16 idling rough (yanta)
because i didn't know i could do that on my obd2 car now i know i am going to do it today thanks for you help tho
Old 10-18-2004, 11:08 AM
mrnice1058's Avatar
ok i did the cel test and i am getting only one code it is a code 14 let me just make sure i got this right it is one long light then four little blinks so that is a 14 IAC (EACV) - idle air control valve correct? now how do i go about trouble shooting this?
Old 10-18-2004, 11:19 AM
B3AS's Avatar
the iac valve is on the back of the intake manifold. unplug the wires coming from it and see how it runs. you may have to mess with ur idle screw to keep the motor from stalling. your most likely going to have to replace it. about $200 from honda. you can drive with it unpluged, if that makes it any easier, but your going to need to replace it soon since its getting cold out. until then u might want to sit with ur foot on the gas for a minute to warm it up.
one thing that u might want to check though, my ecu was throwing the same code (21 on my ecu) and i replaced the iac valve and it didn't solve the problem. my ecu was bad. if u can, try running a different ecu and see if you still have the problem. good luck
Old 10-18-2004, 11:26 AM
mrnice1058's Avatar
Default Re: b16 idling rough (Love2race)
kool thanks alot i am going to try that my boy has a chipped p30 and see if i get the same code along with the knock sensor since i don't have that wired on mine because i don't need it with the p28. but that helps me with one problem now the other problem..i will make a new post for it...thanks guys
Old 10-18-2004, 12:10 PM
B3AS's Avatar
i mentioned my code for the IAC valve was 21, that was with a p30. hope that saves some time
...i think
Old 10-18-2004, 08:30 PM
mrnice1058's Avatar
ok i just came accross something i have an obd2a car that was non vtec and i was shown the ffsquad website
http://technet.ff-squad.com/
on the wiring for the IACV now i did the two wire plug and i thought that with the obd2a(car) to obd(ecu) convertion kit i didn't have to do the whole moving of the wire does this make any sense or was my information wrong about not having to move the wire? please let me know thanks
Old 10-19-2004, 08:13 PM
mrnice1058's Avatar
anybody know??
JohnnyBuilt
07-23-2011 05:19 AM
00361itr
06-05-2005 11:16 PM
mrnice1058
10-15-2004 06:58 PM
chirp2hrd
06-08-2003 03:15 PM
crxgurlllll
10-21-2002 10:39 AM
Quick Reply: b16 idling rough
