Is This Normal For An Engine?
Old Oct 15, 2004 | 12:30 PM
D16SohcVtec's Avatar
Default Is This Normal For An Engine?
I searched, but didn't find what I was looking for. I have a d15b with about 100k miles on it. All stock and rarely was run passed 4,000rpms and didn't brunted oil or smoke. My valve cover gasket started to leak pretty bad because one of the valve cover bolts broke. I replaced the bolt, the valve cover gasket, and the spark plug seals. The spark plugs had some oil in it. One had a lot of oil in it. So I pulled out the plus, cleaned them and checked to see if they're still ok. So I stucked them back in and I cranked the car.
When I turned the car on it smoked black for a bit. And then kepted smoking black after I left it on for about 15 minutes.
My question is, is that normal? Because of all the oil that was in the spark plugs. Will it eventually go away? Thanks for your replies.
Old Oct 15, 2004 | 12:34 PM
ej1 pilot's Avatar
Default Re: Is This Normal For An Engine? (D16SohcVtec)
run the car for a little while and see if it keeps doing it...you may need to get new plugs, and one of your seals might be going bad
your symptoms sound kinda like a bad headgasket
Old Oct 15, 2004 | 12:35 PM
Lucky_Smurf's Avatar
Default Re: Is This Normal For An Engine? (Art In Motion)
Could be also try a compression test. You might have a ring problem.
Old Oct 15, 2004 | 12:36 PM
Calvinator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SohcVtec &raquo;</TD></TR><TR><TD CLASS="quote">I searched, but didn't find what I was looking for. I have a d15b with about 100k miles on it. All stock and rarely was run passed 4,000rpms and didn't brunted oil or smoke. My valve cover gasket started to leak pretty bad because one of the valve cover bolts broke. I replaced the bolt, the valve cover gasket, and the spark plug seals. The spark plugs had some oil in it. One had a lot of oil in it. So I pulled out the plus, cleaned them and checked to see if they're still ok. So I stucked them back in and I cranked the car.
My question is, is that normal? Because of all the oil that was in the spark plugs. Will it eventually go away? Thanks for your replies.</TD></TR></TABLE>
Well, Im guessing since all that oil went to the cylinders, then the engine is just burning away all the excess oil, causing that black smoke. I guess you would have to wait and see if it goes away or not.
Old Oct 15, 2004 | 01:10 PM
gobblebox59's Avatar
Default Re: Is This Normal For An Engine? (xtremeazian)
black smoke, your running too rich
Old Oct 15, 2004 | 01:45 PM
LSvtechatch97's Avatar
Default Re: Is This Normal For An Engine? (gobblebox59)
sell your car and go to school. learn to read and write correctly.
TheCrimsonGhost666
Apr 22, 2010 03:50 PM
turboteg7
Jan 1, 2009 09:43 AM
BlueRex1020
Feb 8, 2007 09:17 PM
88CRsXy
12
Feb 6, 2006 10:07 PM
lke2drvgsr
Sep 29, 2003 07:25 PM
