what wires control the fuel pump?
Ok ive had a problem lately the car will crank over but fuel pressure gauge says no fuel pressure at all. So i jumped Slot 5 & 7 on the main relay and i got 40 psi of fuel pressure. so i went to honda a bought a brand new Main relay. i threw it in and nothing! so im trying to figure out what wires on the engine harness control the fuel pump. are there any connectors for the fuel pump? i really need your help guys
I'm really 2slow
a week ago my car wouldnt start becuase of the ground that goes to the tranny. Wasnt making good connection so i put one directly from the battery and starts up fine all the time.
Electrician
Well if you pull up on your rear seat, you'll see the fuel pump cover there with a couple wires going to it. If you pull up on the rear carpet, you'll see the wires routed in front of the rear seat. The one that sends signal to the fuel pump is the YELLOW/GREEN wire.
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">are there any connectors on the engine harness that control the fuel pump?</TD></TR></TABLE>
nope. there's nothing on the engine harness going to the fuel pump
PapiPezzi
19
05-31-2013 03:38 PM
