noobie coolant question
Guest
Posts: n/a
the coolant level is pretty low in my resoveir tank (clear plastic tank) i could see water and a little green, So do i fill that up with coolant to the max line or do i add coolant to the radiator(the hole the coolant cap is covering)?
also what kind of oil can I use for my b16 a-1 motor?
Re: noobie coolant question (SpoonIntegra808)
for the coolant prob, mix 50/50 coolant and water and add to the clear box, if there is room to add to the radiator , add some to there also
i just use valvoline 10-30 engine oil. the brand is just persoanl preference. good luck, and make sure to check your fluid levels every once in a while
Re: noobie coolant question (stripes777)
One question about the coolant/water, the 50/50 of each. Does this depend on the severe conditions of the car? Winter's freezing here, should we put less water and more coolant when mixing them to prevent freezing?
Re: noobie coolant question (Tmak)
since ur in need of coolant for sure..may as well put in some water wetter
and fill the rest of the way with distill d water
but whatever u do..don t use tap water..use distill d water only
50/50 should work fine there. It gets pretty cold here too, and I haven't ever had a problem with that setup.
-Shane
-Shane
patastinky
01-21-2003 05:43 PM
