How much over heating does it take to cause damage?
The ******** who sold me the car did not leave much water in the radiator. So today as I had the air on in first I heard it knock a bit...looked at the temp gauge and it was right on the H redline. Pulled over and poped the hood. Took off the cap....let it vent, Added water after 20 minutes & then it ran fine & the air worked much better. I did not notice it getting hot because no light came on and it ran fine, but the air was getting warm & I knew something was up. Do you think I damaged anything? Prolly not but I want to hear an opinion. No wise *** remarks please...
* B A N N E D *
1 Post
Re: How much over heating does it take to cause damage? (EnKidu)
change out all your coolant. Then, check your spark plugs. They can tell heat damage sometimes. DO a compression test. Also, check for any part of your radiator or engine that may be blue from heat damage. change your oil and transmission fluid and check for any particles.
crashN2u
10
12-29-2005 08:23 PM
