*LOOK* Please indentify this screw
Is this the oil fitting screw that goes to the turbo? How can I find this screw? What is this screw called in the stores and what size is it? My turbo is a IHI Apexi Turbo.
Re: *LOOK* Please indentify this screw (trooper0641)
That is a pipe thread coupling/fitting. You'll find it in the plumbing department of any hardware store. You want it to be brass....they should have a whole section with fittings that look like that. I have no idea what size that one in the picture is....but its a male to male fitting....probably 3/8".
That is not the fitting that screws into the turbo. The pictured kit is for a t3/t4 setup. The fitting to the left of the circled fitting goes into the turbo w/ an adapter which isn't pictured. I had or found a pic of the fitting you needed, but I can't locate it right now. Check back...
Re: *LOOK* Please indentify this screw (RacerXI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerXI »</TD></TR><TR><TD CLASS="quote">That is not the fitting that screws into the turbo. The pictured kit is for a t3/t4 setup. The fitting to the left of the circled fitting goes into the turbo w/ an adapter which isn't pictured. I had or found a pic of the fitting you needed, but I can't locate it right now. Check back...</TD></TR></TABLE>
hmm alright, thanks for your help.
So is this the oil fitting screw that goes in the turbo? Because im getting mix answers
Location: Why so you can pretend like youre interested, FL/OK
Message user Flamenco-T on here, he sells those kits all day long. I am sure he would be able to tell you.
Here: https://honda-tech.com/zerouser...=5619
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote">
So is this the oil fitting screw that goes in the turbo? Because im getting mix answers </TD></TR></TABLE>
Re: *LOOK* Please indentify this screw (INVALID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INVALID »</TD></TR><TR><TD CLASS="quote">Message user Flamenco-T on here, he sells those kits all day long. I am sure he would be able to tell you.
Here: https://honda-tech.com/zerouser...=5619</TD></TR></TABLE>
I got this oil feed line in my car. Pay attention and ill tell you how it goes.
See the silver piece thats on the bottom left? Ok that plugs into your block (where the oil sender use to be).
If you want to keep the oil sender then youll use the piece thats right to the right of the silver piece to make like a T to add another piece.
Now the piece your asking about goes into that T piece (if you dont want the sender then just tap it into the silver piece alone.)
Now you get your oil feed line and screw it on to that piece.
The piece thats on the left that looks like a L goes into your T3/T4 oil feed hole, and then you connect the other piece of the feed line back into that.
Sorry dont know the names of each but thats how it goes. And Fast-Turbo took off there tortorial
Re: *LOOK* Please indentify this screw (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">I got this oil feed line in my car. Pay attention and ill tell you how it goes.
Sorry dont know the names of each but thats how it goes. And Fast-Turbo took off there tortorial </TD></TR></TABLE>
Ok thanks so I guess that L peice is really the fitting that goes to the turbo. The guy above posted that the picture i posted was for a t3/t4...my turbo is the Apexi IHI, would that be any different or would all the screws look just about the same?
Yes, for a T3/T4 though, or just a T3, T4 and i think T25/28 (cant remember but go to fast-turbo and they tell you) Every turbo is different for that last piece.
The other 3 youll get anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Yes, for a T3/T4 though, or just a T3, T4 and i think T25/28 (cant remember but go to fast-turbo and they tell you) Every turbo is different for that last piece.
The other 3 youll get anyway. </TD></TR></TABLE>
ok thanks for clearing that up for me. im a newbert to the boostin world.
Honestly you should try the FI forum, but there are a few boost heads in here but FI would be a much better place to research.
GruvyTune
12-12-2001 03:03 PM
