wierd noise when i accelerate, bad wheel bearing?
from a dead stop if i hold the rpm to 1.5k or a lil more and let of the clutch normal, it sounds like something is rubbing. like somethings dry
Re: wierd noise when i accelerate, bad wheel bearing? (93CivicSI)
wheel bearing
differential bearing
tire rubbing
but first of all... check your tranny fluid!!!
check the brakes, maybe they grind
tire rubbing
Re: wierd noise when i accelerate, bad wheel bearing? (KKVTi)
Does it do it if you are coasting in neutral. If so that its somthing in the brakes or outside drivetrain. If it does it all the time then it could be in the tranny aswell as outside.
Re: wierd noise when i accelerate, bad wheel bearing? (boo bees)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boo bees »</TD></TR><TR><TD CLASS="quote">Does it do it if you are coasting in neutral. </TD></TR></TABLE>
nope only from a stop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KKVTi »</TD></TR><TR><TD CLASS="quote">wheel bearing
tire rubbing
check the brakes, maybe they grind</TD></TR></TABLE>
i just change my tranny fluid
tire rubbing
frostcivic
05-11-2006 02:23 AM
coot_er
03-29-2005 03:47 AM
