z6 head on y8 block.....which head studs do i use?
if mating a z6 head on a y8 block and i wanted to use arp head studs....would i use the y8 ones? i tried searching but only found and answer that when putting a b16 head on a gsr block u use the gsr studs. same deal?
Re: z6 head on y8 block.....which head studs do i use? (d15b7racer)
i would say you would have to use the y8 studs because the z6 might have diff threads or somthing but can i ask why your putting a z6 head on a y8 block???
Re: z6 head on y8 block.....which head studs do i use? (opkjoblacsh)
I believe the Z6 studs will be too long for the D16z6 head swap. On the z6 head, there and 9 bolt locations that are the same height, and one that is a little higher than the other 9. I believe a z6 stud is the correct length for the one location that is a little higher, and y8 studs are the correct lengths for the other 9. The y8 stud may be long enough to bolt down on the last location, but I had both sets so I went ahead and mix and matched. I used a D15b vtec head but I also have a z6 head to compare with. The bolt layout looks the same.
tampabitches
11-29-2008 06:06 AM
socialburn0035
07-24-2008 03:14 PM
keepinitsimple
02-17-2005 11:32 AM
Cruiser G
02-06-2004 11:26 AM
