SO MAD NEED help.!!!!!!!!!!!!!!!
ok iam try to explain this the best i can. I was putting in my axels today, well i did the driver side just fine. Then it comes time for passanger side, well iam trying to take the controle arm off so i can swing it to put the axel in. It took me forever to get the controle arm off. i put the axel in and bolt everything except the controle arm to that v looking think on top (dont even kno wut its called) well that thing has a stud poping out that fits in the whole for the controle arm. so i try to put it on and for some reason the stud spins everytime i try to turn the screw. iam like WTF...so i thought maybe the wd40 is making it slip so i cleaned it off, but still the same bs. DID i *** it up??? and do i need to replace it??
Re: SO MAD NEED help.!!!!!!!!!!!!!!! (gezer)
First of all go back to school becasue you dont use correct grammar or spelling. Second of all I think you are talking about your lower ball joints and that nut is a bitch to get on and off. It just takes time and the right touch to get it on correctly.
Re: SO MAD NEED help.!!!!!!!!!!!!!!! (FUKuPAYme)
wow...first of all go **** ur self. that helps me alot what u just said. I dont give a *** how my grammer is. bottom line is u got the point didnt u. AND MORON the whole thing is ******* spining i have taken it of before and this is the first time this happend. i dont care what touch u have that thing will not go on...it just spins the whole thing. in the future dont ******* comon on my threads and try saying stupied **** if you have nothing helpfull then dont say ****.
See you spelled like 4000 words wrong in that post and used them incorrectly too. Take the nut off and go ask someone who knows what they are doing because you don't!
Moderator
it is the upper ball joint that hold the knuckle to the A at the top.....
impact gun.....
if that doesn't work stick your pickle fork in there and apply pressure down on the nut while you turn the nut.....it don't make sence....but it will work
impact gun.....
wow wow wow oowoowowowowow.....dude go **** your self. PLZ come to my house right now and try it....then iam kik u in the head cause your a *** with 200 posts and u trying to school me like iam a moron. if you have an answer then say it if not then go **** your self.
edit: not you chad. thanks
I think you're talking about the castle nut on the bottom, right?
Looks like it's got teeth on it... If so, what we did was have someone stand on the rotor then it'll lock it up so you can tighten it...
Dunno if that's the right way, but we didn't have access to an impact gun, and it worked...
2004.10.15
The "V-thing" I take it is the upper control arm? Well, it is a joint, and if it's spinning, it's BROKEN. The threads should never spin and that joint should not move by hand (if I remember correctly).
Anyways, an impact gun will only spin that joint more and probably destroy it. It sounds like you need a new upper ball joint to me... your control arm is the L-shaped piece that connects on top of the hub? If so, the top of that L-shaped arm is connected to the "Upper Control Arm" at a joint with threads and a nut with a hole for a cotter pin... if so, yea, you need a new joint.
Good luck.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezer »</TD></TR><TR><TD CLASS="quote">. PLZ come to my house right now and try it....then iam kik u in the head cause your a ***
edit: not you chad. thanks</TD></TR></TABLE>
SRY i bee their now end u kik my in head cuz i a fagg... u iz write ee iz stoopid
so your saying your a better person??? yet your the one acting like a two year old....real cuteeeeeeee!!!!!!
editption man got it, thats what iam talking about, so it shouldnt spin. *** aite well thanks i guess i have to replace it, thanks for the people who helped or tryed to.
Damn your car looked fine at Victor's house 2 days ago. WTF did you do?! It sounds like you got your answer, and I hope it gets fixed.
And FUKuPAYme, you are a stupid *** no0b trying to act tuff. Stop trying to be an e-thug and get over youself. You don't know **** about what he is talking about, and you don't know anything about everything. Please leave and never come back.
Have a nice day.
Have a nice day.
Re: SO MAD NEED help.!!!!!!!!!!!!!!! (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life »</TD></TR><TR><TD CLASS="quote">
Sorry but he's just ******* ignorant. How does someone expect a real answer when he can't type a sentence?
Outstanding. Some of you guys honestly disgust me. Quit your bitching and moaning over everything and stop the name calling.
Threads locked because you people can't seem to get along and there is very little technical help being given out.
BTW, registration date and post count means jack ****.
flushek
19
10-06-2023 08:48 AM
plaiskool
33
08-07-2004 03:42 PM
