help settle this fight at work
Help we my pennies
this kid at work swears u can remove an alternator with out removing the IM or the axle. whats the best way to remove an alternator from a ef/da/eg/ek/dc
please list all the possible ways
put the thang down flip it and reverse it damn dont cha know?
oh wait. thats not how...
i know that when i removed mine (actually dad did) from my ef back in the day, intake manifold came off. however, i'm pretty sure that with a little finegaling, you just have to get it right. i'll find out and get back to ya
HT Order of Merit
Re: help settle this fight at work (idriveadelsol7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 »</TD></TR><TR><TD CLASS="quote">remove alternator bracket... that's it. somebody told me you don't even need to remove anything. did it yesterday...</TD></TR></TABLE>
Yea I've done it a few times. Rather simple actually, just a tight squeeze.
Re: help settle this fight at work (BLUE EH3)
oh my 96 hb, i didnt remove anything.. loosed the all bolts, then loosed the bolts for that whatever u call it by the clutch and brake reseviors, then bend it back a little without fu*king up ur lines.. then shake that monkey out! its tricky. ur going to have to do it a few times to get used to it. i didnt think it was possible until a friend helped me on it while i was stressing.. ahah
Help we my pennies
sounds like a good idea but..<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 »</TD></TR><TR><TD CLASS="quote">remove alternator bracket... that's it. somebody told me you don't even need to remove anything. did it yesterday...</TD></TR></TABLE>
i undid the 12 holding the ground on unplugged the harness then undid the 12 on top for the tensioner then the 14 on bottom for it to pivot on
then i dropped it out the bottom and picked the new one up from the same hole i dropped the old one down...nothing but the alternator came off
Location: Why so you can pretend like youre interested, FL/OK
First punch the guy in the face for being right..
Remove the two bolts holding the alternator in place, the ground on top, and the wire harness for it of course. You'll also need to remove the power steering and ac belts as well, unless you're just replacing the alternator and not the belt.
yeah I did this with the help of a lift and wiggled that sucker out.
Re: help settle this fight at work (grlracer97)
I had to remove my oil filter to get the alternator out the bottom. I changed my oil at that time anyway so it wasn't a problem. This was on an EG with b18 swap. Wouldn't it matter what car/motor you have?
footwork mastery
Re: help settle this fight at work (RTI)
i did it in my old crx with the stock d16. was a very tight sqeeze but it can be done. although if i ever had to do it with my b18 i don't think it woulda fit..
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">how do u do it with a b motor in a ek or eg</TD></TR></TABLE>
I've got a B18C1 in my hatch and I have removed and installed the Alternator in the car many times without removing anything. It's easiest done from under neath. It's tight, but it will fit, and you can reach all the bolts on the bracket this way. A little from the top and a little from underneath and it can be done. Easy.
later
later
MR_Se7en
03-25-2008 10:04 AM
Jeff
14
10-19-2005 12:02 AM
sopiwnykg
12
08-02-2005 04:52 PM
90 Si Hatch
09-10-2004 03:48 AM
