question about adjusting the glove box
i know this sounds a lil ****. on my 00 si the glove box isn't flush wit the dash when its closed, and i can't figure out how to adjust it.
Re: question about adjusting the glove box (ian22)
there should be a 8mm bolt under neath with the glove box closed you can see it by lying on your back,
undo this bolt on each hinge and push the box in until flush and then tighten
Re: question about adjusting the glove box (johniericeboy)
ive seen those, its the two that hold the glove box in place, they r hooks that hold it in one position. should i flatten them out and do it that way
i have a 2000 si with the same problem all i did was take m y heat gun and heated up the side that poped out the most and just pushed it in slowly till i was happy how it sat.
