my sisters AUTO TRANNY leaking antifreeze...possibly problems?
leaking where the two casing bolt together and cant figure out why? is antifreeze even suppose to go through the tranny?
Re: my sisters AUTO TRANNY leaking antifreeze...possibly problems? (ek_99_SiR)
It won't be leaking antifreeze.
Check the hoses that goto the head and t-stat right behind the head above the tranny. You'll find a crack in the hose or leak in the connection I'll bet.
Re: my sisters AUTO TRANNY leaking antifreeze...possibly problems? (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">It won't be leaking antifreeze.
Check the hoses that goto the head and t-stat right behind the head above the tranny. You'll find a crack in the hose or leak in the connection I'll bet.</TD></TR></TABLE>
Agreed. Coolant Wont be flowing through the tranny, it has to be dripping on it from somewhere else
Re: my sisters AUTO TRANNY leaking antifreeze...possibly problems? (SicilianSpeed42)
thats what i thought... but everything is dry... except the bottom of the trans.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_99_SiR »</TD></TR><TR><TD CLASS="quote">thats what i thought... but everything is dry... except the bottom of the trans. </TD></TR></TABLE>
maybe it's tranny fluid.....pink stuff normally.
one way to tell is taste it, if it kinda tastes sweet then it's antifreeze. But spit cause it's poisonous and will make you blind. lol, so just joking, please don't taste anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_99_SiR »</TD></TR><TR><TD CLASS="quote">its antifreeze... bright green antifreeze</TD></TR></TABLE>
didn't mean to insult your intelligence.
Re: (duggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duggy »</TD></TR><TR><TD CLASS="quote">You guys do know.....automatic transmissions have coolant running through them.</TD></TR></TABLE>
no
no
Re: (duggy)
I seem to remember that they sent fluid out for cooling(ie: through radiator), not bring coolant in.
Re: (splitime)
I seem to remember that they sent fluid out for cooling(ie: through radiator), not bring coolant in.</TD></TR></TABLE>
Correct.
Correct.
coolant DOES FLOW TRU AN AUTO but (its a special resovoir for it) tranny its look at the bottom of radiator there should be some line goin to the tranny check does lines for leaks,,, auto is differ then manual
Re: my sisters AUTO TRANNY leaking antifreeze...possibly problems? (hatch-E-vanish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch-E-vanish »</TD></TR><TR><TD CLASS="quote">coolant DOES FLOW TRU AN AUTO but (its a special resovoir for it) tranny its look at the bottom of radiator there should be some line goin to the tranny check does lines for leaks,,, auto is differ then manual</TD></TR></TABLE>
Please remove yourself from this thread. You clearly do not know what you are talking about. Would you bet me say 5 million dollars that you are wrong? If so, I will personally come to where you live, disassemble a Honda automatic transmission in front of you, and ask you to show me where coolant flows through it.
The "resovoir" on the bottom of the radiator IS TO COOL THE AUTOMATIC TRANSMISSION FLUID... damn it.
Go Tigers!
auto tranny fluid passes through a special resivoir found only on auto radiators. Auto trans fluid is red. You guys do realize that they have certain types of antifreeze that isn't neon green, right? i've used a red/purple prestone one before. maybe there's a confusion.
edit: perhaps he's using heavy duty anti-freeze?
Your an idiot
Your an idiot
Re: my sisters AUTO TRANNY leaking antifreeze...possibly problems? (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">
Your an idiot</TD></TR></TABLE>yes he is. and ive figured out the problem... thanx for the help guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_99_SiR »</TD></TR><TR><TD CLASS="quote">yes he is. and ive figured out the problem... thanx for the help guys</TD></TR></TABLE>
What was it? share the knowledge.
Re: my sisters AUTO TRANNY leaking antifreeze...possibly problems? (old man neri)
top rad. hose was leaking but showed no visible signs of it... ran down cracks and made it very difficult to tell where the fluid was coming from... and checking all the clapms i found that the upper hose wasnt even clamed tightly enough to hold any pressure...piissed me off it was so simple
lolz... well... glad it was a simple fix. we've all had those brain farts before...
suthernbred904
11
01-04-2009 03:11 PM
