Engine Conversion Question - GSR into an EG
hi all,
Just signed up to this forum... some very interesting information about engine conversion
Just got a couple of question i need clarifying..
Basically im putting in a GSR motor in an EG GL (dual carby).... the GSR is running an obd2 ecu, but i onli have an odb1 wiring harness... obviously they wont directly connect together..
i know i could be buy the obd1 convertor to the obd2? or should i jsut get the obd2 wiring harness? Will the obd2 wiring harness work in the EG??
wat do u guys recommend
any hlep would be greatly appreciated
Re: Engine Conversion Question - GSR into an EG (benson03)
The obd2 GSR engine harness will plug directly into your civics obd1 main harness.
The obd2 GSR ecu will not, however. Just get a obd1 gsr ecu and you are set.
Re: Engine Conversion Question - GSR into an EG (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">The obd2 GSR engine harness will plug directly into your civics obd1 main harness.
The obd2 GSR ecu will not, however. Just get a obd1 gsr ecu and you are set. </TD></TR></TABLE>
Correct!
Here's a really good thread done by member- B18C5-EH2.
https://honda-tech.com/zerothread?id=856396
Correct!
i got this conversion a obd2 gsr motor in a obd1 eg6 hatch.. was very easy. everything lined up.. and went well.. if u need any help or any parts at all email me at anderhol2@hotmail.com thank you
i ran into the same problem. i got a P28 ECU OBD1 that was chipped for a GSR. stay OBD1. P28 or P72 on the ECU.
Re: Engine Conversion Question - GSR into an EG (93gsrhatchbrid)
where would i be able to source a GSR obd1 ECU in australia??
wat other alternative options are there? will obd1 affect the performance of the car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benson03 »</TD></TR><TR><TD CLASS="quote">where would i be able to source a GSR obd1 ECU in australia??
wat other alternative options are there? will obd1 affect the performance of the car?</TD></TR></TABLE>
You might have to have one shipped from overseas.
Alot of people here in the states convert to obd1. It wont affect the performance. It just simplifies everyting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benson03 »</TD></TR><TR><TD CLASS="quote">where would i be able to source a GSR obd1 ECU in australia??</TD></TR></TABLE>
You guys got ebay over there?
i got mine from ih8ricerz here on HT. i think he might have one left. plus he's very fast on shipping.
cnydc2
07-15-2009 05:10 AM
