anyone know how to put ITR suspension on EK
1 Post
Hey
i found this really good deal on itr suspension. but i have a 98 ek and i know that the shoucks wont fit.
But the guy is willing to give me wat ever i need from his itr to install it on my ek.
My question was:
What do i need from the Integra Type R to install its suspension on to my EK 98
grate thanks to the people with answers
My question was:
Re: anyone know how to put ITR suspension on EK (alispoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alispoon »</TD></TR><TR><TD CLASS="quote">Hey
My question was:
grate thanks to the people with answers </TD></TR></TABLE>
You can use the civic OEM struts if you use the civic LCAs.
You need the following:
Complete front knuckles with disc, pads, calipers
rear trailing arms with disc, pads, calipers, and parking brake cables
also if you use the jdm itr suspension then you need the jdm itr axels 36mm, if USDM then you can use ur civic axels
Thats all you basically need
thats exactly wat i had gotten and installed on my ek
My question was:
1 Post
Re: anyone know how to put ITR suspension on EK (AL ASPIRATED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AL ASPIRATED »</TD></TR><TR><TD CLASS="quote">
thats exactly wat i had gotten and installed on my ek </TD></TR></TABLE>
but i dont want to do 5 bolt conversion, so i really have to use the itr disks.
cause as much as i know so far, is that i need the itr lower control arms for the rear and the front needs nothing.
but im still not sure, thats all i know so far.
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
you cannot use the itr rear lca's. they will not work on an ek. aside from that, the front spindle and rear trailing arm complete will work.
but im still not sure, thats all i know so far. </TD></TR></TABLE>
wat are you trying to do? the strut and spring?
1 Post
no man the thing that im tring to do is to fit in the type r shoucks and springs thats all.
and all im asking is that wat alse do i need from the Type R to do this.
if its the coilover, which i think it is. you need the subframe and LCAs.. i have seen it done, its possible on an EK.. worth it?! no.. just get CTR coilovers.
Re: (ej0513)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej0513 »</TD></TR><TR><TD CLASS="quote">if its the coilover, which i think it is. you need the subframe and LCAs.. i have seen it done, its possible on an EK.. worth it?! no.. just get CTR coilovers.</TD></TR></TABLE>
, really not worth it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alispoon »</TD></TR><TR><TD CLASS="quote">no man the thing that im tring to do is to fit in the type r shoucks and springs thats all.
and all im asking is that wat alse do i need from the Type R to do this.</TD></TR></TABLE>
btw its called a strut not a shock
Re: (ej0513)
You will need the ITR LCA's to accept the ITR rear shocks, but the EK LCA's are not the same as DC2. I agree with the others, just buy coilovers made for your car. BTW, are you getting the ITR rear sway bar too? I think that alone might make as much of a difference in handling as changing to ITR springs/struts.
1 Post
yes, ITR coilovers and, this isnt the stock coilovers, its OMNI power coilovers that where made for ITR only, and im trying to see wat else from the ITR do i need to do this.
So far i know that i need the ITR lower control arms; thats not a problem i can get those from him too.
Wat about the front is there anything that i need from the itr for that?
1 Post
Re: (ej0513)
so the fronts are cool then?
and all i need is the rear forks? r u sure that thats is cause all i know is that the fronts have forks but not the rears.
anyways im gona talk to the omni power guy and ask him wat i should do.
thanks for ur help
thanks for ur help
whoa! wtf.. fronts have forks? hmm.. well in that case.. take a pic to we could see it so we can tell you what you need.. any who.. this is what it should look like. its a small pic, but you can see the fork for the rears and the other thing for the front.
edit: maybe what your talking about forks on the front is that this seller included the OE piece that you already have on your EK.. is that it?
1 Post
Re: (ej0513)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej0513 »</TD></TR><TR><TD CLASS="quote">whoa! wtf.. fronts have forks? hmm.. well in that case.. take a pic to we could see it so we can tell you what you need.. any who.. this is what it should look like. its a small pic, but you can see the fork for the rears and the other thing for the front.
edit: maybe what your talking about forks on the front is that this seller included the OE piece that you already have on your EK.. is that it?</TD></TR></TABLE>
well yah i was talking about the front fork thats already on my ek, but if ur talking about the rear, then i know that there is that fork i.e. the bottom piece that comes off. is that wat ur talking about? and r u saing that if i call omni they would sell me just that piece for ek whick will also go right ont the bottom purch?
Re: (ej0513)
I didn't know the rears have forks. Are these for ITR? I thought ITR rears mounted to the arm differently. They have the bushing in the shock instead of the arm unlike other civics and integras.
ok ok.. ill try to end this now.. the front.. you should have no problems. as for the back.. call Omni and see if they will sell you just the fork.. in the pic i posted.. the coilover with the fork is for the rear. ask them.. they may just sell it to you.
Re: (AL ASPIRATED)
btw its called a strut not a shock </TD></TR></TABLE>
They're shocks. 01+ Civics and RSX's use struts.
1 Post
Re: (ej0513)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej0513 »</TD></TR><TR><TD CLASS="quote">^ sorry! both of you are stupid! they're dampers! ***... lol.. but seriously.. dampers people.. they "damp" spring occilation.</TD></TR></TABLE>
hahah who cares wat their called, as long as u guys know wat im talking about then that does it.
CHAMPwhteEK
06-27-2005 11:54 AM
{Powered by VIII}
03-19-2004 01:00 AM
