Does anyone have this rubber plug from an O2 sensor?
Sorry, but I don't know where else to post this. I need the rubber plug that the secondary O2 sensor wires go through. I bought a universal sensor, which doesn't come with it, and need something better than duct tape, which I'm using now. If someone has an old defective O2 sensor with this plug, please let me know. Thanks!
Re: Does anyone have this rubber plug from an O2 sensor? (USE2B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USE2B16A »</TD></TR><TR><TD CLASS="quote">Bump for suggestions.</TD></TR></TABLE>
Go buy a grommet and cut to fot. /that plug stock is mated to the secondary O2. You would need to cut it off.
Re: Does anyone have this rubber plug from an O2 sensor? (Hybrid93Eg)
The wires are go through 4 holes in the grommet. When I started running a test pipe and Hondata, the 2nd O2 sensor was disconnected and I use the stock plug. It's inspection time right now, and since I need a new O2 sensor anyway, I thought I'd see if anyone had a defective O2 sensor with that plug attached. I'd like to just push the new wires through before soldering. Especially with the snow and salt, I'm concerned about moisture getting in there.
