which turbo kits?
which turbo kits?
Wuz up guys,
I just bought a civic si and i want to turbo it. Its got headers,exhaust,cold air intake,lowered,head gasket, and gsr rims. Which turbo kits are good for me? I want only complete kits though
Re: which turbo kits? (rells2000bluesi)
you know that if you turbo it your gunna have to take off your headers and intake right? lol you might as well just keep it NA, but if you want to turbo it just get the greddy kit or similar. Anyone with some mechanical knowledge can install it themselfs.
Re: which turbo kits? (JayDiemB16aCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDiemB16aCivic »</TD></TR><TR><TD CLASS="quote">Turbo Forum </TD></TR></TABLE>
LOL I was waiting for that
Thanks guys I gotta look into some pistons and rods or something so i can run higher boost and crush Evo's and Sti's. Would pistons and rods do me good?
Re: which turbo kits? (RTE117)
I wanna keep it around 2500-3000 dollars or less if i could because I work part time and im still in high school. I wanna get around 300 hp or more if I can. I wanna be in the 12's. What do you suggest?
lol. piston and rod is pricy. just run turbo wit ur stock internal for now but low boost. But if ur lookin for piston u would have to get the type for running forced induction. Theres 3 types of piston styles.Theres Inverted dome pistion(which is for turbo/n20)Theres Dome piston(for n2o/na)and Flat top piston(na only). But if ull lookin for brand also, i perffer JE
Location: University of Massachusetts, Amherst, Ma, US of A
arias, je, and weisco pistons are all good, I'm running je 8:5:1 pistons with a set of eagle H beam rods. Basically anything forged is good! I heard bad things about CP pistons. things like cracking from too much boost. i.e. anything over 20 psi. other than running a good amount of boost you can either
A. sleeve it
B do a blockguard
I'd recommend sleeving it with Darton iron sleeves. Good rep, good product, save your *** if you boost a little too much. sleeves basically make the block bulletproof.
Blockguard is a safe way to boost, but requires a bit more tunning. The keyword is SAFE. Don't be stupid and boost like eleventey billion pounds of boost and think your motor is gonna hold all that. cuz it won't.
best of luck
A. sleeve it
B do a blockguard
best of luck
