Check engine light
Check engine light
I recently Put my DC JDM 4 into 1 header and carsound high flow cat. I had taken both items off about a year and half ago and put the stock ones back one to pass smog.
My problem now is that after a certain time the check engine light comes on. Its usually about 2 weeks after running it. The car runs great even when the light comes on. I didnt pull the code like I should have. I just unpluged and plug the battery. I know I should have gotten the code and I would be asking this dumb question.
So do you guys think its a bad cat?? Or something else?
Re: Check engine light (Dodger2940)
Ok so it happened again and the code is:
P0420 Catalyst System Efficiency Below Threshold. Does this mean bad cat? OR not installed right?
Re: (Dodger2940)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dodger2940 »</TD></TR><TR><TD CLASS="quote">You mean to see if the 02 sensor is pluged in right or if there is a cut in the wires?</TD></TR></TABLE>
Right. Check the wiring, clean the plug, throw some dielectric grease on it and go from there.
(You didnt hurt the sensor?)
Cats shouldnt go bad for over 100k miles - and since you just put yours back on recently, Im guessing it isnt that high.
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">
Cats shouldnt go bad for over 100k miles - and since you just put yours back on recently, Im guessing it isnt that high.</TD></TR></TABLE>
Alright I will do that. thank you. How do you know if you hurt the sensor?
Laura Ilkenhans
10-13-2012 06:47 AM
