ObdO Block Convert to Obd1
Location: With my POS D15B2, Whereever whenever, United States
Alright as long as I have all the sensors from an obd1 block can I convert my obd0 block to obd1.
I got suckered because I ordered an b16a2, however, I received a b16a2 block from a 91 block.
How, I do not know probably from that freakin integra XSI bullshit.
So is it possible, in regards to the knock sensor, i have a mugen chip in the p28, that will clear it correct?
Re: ObdO Block Convert to Obd1 (MugenHonda)
Yes, a p28 does not use the knock sensor, so you dont have to worry about that.
If you have all of the obd1 electronics(injectors, distributor, etc) then it is easy to run the motor obd1.
Two things you need to know:
1. On the obd0 blocks, the fan switch is located on the back of the block and has two seperate single pin connectors. Your obd1 or obd2 motor has the fan switch on the thermostat housing and uses one connector with two pins.
2. The timing belt mount(the part that bolts to the block itself) is different on the '90-'93 integras than on the '94-up integeras. You need to bolt on the '94-up mount so it'll work in your car.
Re: ObdO Block Convert to Obd1 (Slopoke)
good stuff
thanks
in regards to the fan switch, which one do i wire it to?
thanks
Offer
10-07-2007 09:05 PM
spooncivic1
07-27-2006 04:57 PM
