glitch around 1500rpm during light throttle. ideas?
i have a 92 eg w/ a b16 swap (cai, exhaust, skunk2 im and chipped p28) during light throttle (in neutral and in gear) there is what seems to be a dead spot in the tps, but only during very light throttle. tested the tps and it was fine. any ideas on what it could be?
Re: glitch around 1500rpm during light throttle. ideas? (hatchedeg)
assuming you used a multi meter to test your tps. there very well could be a break in there. you multimeter will not show it. you need a wave form analyzer to see the glitch. could very well be though
Re: glitch around 1500rpm during light throttle. ideas? (postman)
i did test it with a DVOM, but i ended up changing the tps anyways. what are the chances that both tps' are bad.
any check engine light?
maybe ur car is in Limp mode. i had a bad dizzy and had a code 8 or 9 i think in my CRX before and it did this at like 3500rpm.
try reseting the ecu?
Re: glitch around 1500rpm during light throttle. ideas? (CRXified)
cel 14 which is the iac, but thats been fixed, just havent cleared the code yet. could it be bad injectors because they're the same ones i had in before i did the swap, and it was doin the same thing with the sohc motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchedeg »</TD></TR><TR><TD CLASS="quote">cel 14 which is the iac, but thats been fixed, just havent cleared the code yet. could it be bad injectors because they're the same ones i had in before i did the swap, and it was doin the same thing with the sohc motor.</TD></TR></TABLE>
clear ur code then try it
