vibration is so bad help
i have a 95 civic with 17 inch rims and i have a mild drop on it. my question is that i have had a very bad vibration in the steering wheel and i can't seem to get rid of it i just had the tires balanced and it is still there and whats weird is that when im on the freeway at lets say 70mph it will be shaking like crazy and then it will start shaking mildly like the axle is poping out of place or somthings. can someone tell me what this might be. thatnks
Re: vibration is so bad help (pumatec8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pumatec8 »</TD></TR><TR><TD CLASS="quote">have you had the wheels aligned? if not, this is probably your problem. get the alignment done. </TD></TR></TABLE>
no...Did they do a dynamic or static balance? Static being that the weights are only on one side (inside). The problem with this is that it only balances the wheel up/down, not side/side. They probably used tape weights being that you have aftermarket wheels. Check that out first.
Weapon_R
02-25-2005 11:09 PM
dgc92civic
17
04-30-2003 10:37 PM
