swap troubles
swap troubles
i just installed a b16a swap and it turns on fine but idle sucks ***
im getting these codes
14 IAC (EACV) - idle air control valve
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
Re: swap troubles (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">what ecu are you using? also for the iac, just unbolt it and clean out the screen then install.</TD></TR></TABLE>
im using the P30 ecu
Re: swap troubles (meagainsttheworld)
hmmm. code 36? is it because some eg6' have lsd? the iac is found on the top left of the intake manifold, the throttle cable passes right in front of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meagainsttheworld »</TD></TR><TR><TD CLASS="quote">i just installed a b16a swap and it turns on fine but idle sucks ***
41 Primary oxygen sensor heater </TD></TR></TABLE>
also, the obd1's only have one o2, found on the downpipe right before the cat. easy replace.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meagainsttheworld »</TD></TR><TR><TD CLASS="quote">replace the o2 sensor?
do u think it might be the wires... cuz they had to be extended and soldered</TD></TR></TABLE>
possibly, what civic are you swapping this to.
acctually i just switched two wires around... and reset the ecu and the o2 sensor code is gone... only thing that is left is the iac
also clean the electrical connection to idle air control valve with electrical connector cleaner.
Mine does the samething especially when its cold. I tried a usdm version and it didnt work
88crx1589
07-29-2006 03:17 PM
frankenEG6
05-11-2003 09:47 PM
