brake upgrade question. DA fronts onto EG?
i've got a 94 civic lx and im wanting to put the civic ex or integra front brakes on it. i had the setup on my 95 hatch and its been a little while since i did much with hondas. i know 94+ teg brakes are a direct swap, but are the 90-93 teg setups a direct swap? i've got some 91 teg knuckles, calipers, bla bla bla laying around just wnat to make sure theyll work before i waste my time throwing them on. anyone know? thanks
da knuckles are to tall to put on an eg. they will hit the inner fenderwell area and the only way to get rid of the camber problem with the taller knuckles is to use two camber kits. one a ball joint style and the other the studs in the back.
be professional
Re: brake upgrade question. DA fronts onto EG? (95dxhatch)
'90-93 Integra knuckles have a different geometry. Use only '92-95 Civic or '94-01 Integra knuckles.
be professional
Re: (90dteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90dteg »</TD></TR><TR><TD CLASS="quote">88-91 civic use 90-93 integra</TD></TR></TABLE>
'90-93 Integra knuckles have improper geometry for '88-91 Civics as well. The proper knuckles for 10.3" fronts on an '88-91 Civic are '90-91 EX knuckles. EF8/EF9 knuckles will also work with some tie rod modifcations.
cool thanks guys. i had the da stuff laying around figured i'd ask. its been a little while since i did much honda stuff and forgot if itd work or not. thanks
ImportechPerformance
08-25-2005 04:19 PM
DJNauTicz
07-18-2004 08:24 PM
cdn90civicsi
05-13-2003 11:26 AM
