HELP. Smoke in Vtec?
i have a civic hatch with b18c1, with vtec on a button. whenever i engaged vtec it seems like it wont go past 7 k rpms, and the engine smokes. it was a little low on oil so i added oil and it still does it. Any ideas?
Re: HELP. Smoke in Vtec? (fast_gsr_civic)
you put vtec on a button? hmmm why? could be puttin it into some kinda limp mode.....how did you do that, cuz it could be lowerin you rev limiter some how when engaged....just my. 02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast_gsr_civic »</TD></TR><TR><TD CLASS="quote">i have a civic hatch with b18c1, with vtec on a button. whenever i engaged vtec it seems like it wont go past 7 k rpms, and the engine smokes. it was a little low on oil so i added oil and it still does it. Any ideas? </TD></TR></TABLE>
Like this?
Like this?
Re: HELP. Smoke in Vtec? (Chumbas_EG9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chumbas_EG9 »</TD></TR><TR><TD CLASS="quote">what color smoke.. mine does a normal oil burn on vtec at about 6-8.4</TD></TR></TABLE>
Yeah my b16 does the same thing why is that
is it just the cam change to vtec or just the bigger lobes
so u saying that ur car wont go past 7000 rpm's? is that only when u open vtec manually ? does it happen when u dont open vtec at all?
Re: HELP. Smoke in Vtec? (cambopheonix56)
typical vtec honda valve guides are what make them smoke in the higher rpm's esp. vtec and take that **** off the button and wire it to the computer like it should be before you blow **** up
Re: HELP. Smoke in Vtec? (Slow00si)
also when it was swapped did they wire in the knock sensor that can also cause a rev limiter are you throwing any codes?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow00si »</TD></TR><TR><TD CLASS="quote">take that **** off the button and wire it to the computer like it should be before you blow **** up</TD></TR></TABLE>
its been running fine, then about 1 week ago, i noticed it felt like it was hesitating when i hit vtec. so i did an oil change. then when i drove it for a while then hit vtec there was alot of smoke that came from my hood and even a little in my car. wtf?
when im not in vtec it runs fine. no hesitation or smoke. i mean when it was running fine, there was a little puff of smoke from the muffler, but i figure that was from vtec. but now its from the engine. sorry im trying to explain the best i can, any ideas?
Re: (fast_gsr_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast_gsr_civic »</TD></TR><TR><TD CLASS="quote">when i drove it for a while then hit vtec there was alot of smoke that came from my hood and even a little in my car. wtf? </TD></TR></TABLE>
you know what i could be? VTEC is hitting so hard, your getting mad HPz y0 and burning out without even noticing it. That would explain the smoke coming from under the hood and inside the car
wow vtec on a button. If you have a CEL then the ECU is not switching to the correct fuel Xover. You looking to blow the motor up? looks like your on your way there. Buring oil usually means worn piston rings.
Pirate General...YARRRR
Re: HELP. Smoke in Vtec? (Djaric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djaric »</TD></TR><TR><TD CLASS="quote">
Like this?
LOL wth
win
Like this?
LOL wth
win
