Need Help With Hooking Up An Air/Fuel Gauge To My ECU!
I was just wondering if anyone knew any websites where I could find out with part of the 00 civic si ecu I could run my Air/Fuel wire to. I really dont want to run it to my O2 sensor. If someone could tell me which one, or what website I could find that, I would really appreciate it. Thank You!!!!!!!!!
Re: Need Help With Hooking Up An Air/Fuel Gauge To My ECU! (StrtRacerB16A2)
i'd rather run it to my o2 wire because that wire is easily replaceable, your wire harness for ur chassis (to ur ECU) isnt as easy to fix, dont be lazy just take your time and wire it correctly and neatly
ya i messed up my ecu harness bad doing that.. i ended up having to tap the o2 anyways.. and now that i dont run the gauge any more i just left the sensor pick up wife int he car incase i run one again.
HT Order of Merit
Re: Need Help With Hooking Up An Air/Fuel Gauge To My ECU! (Chumbas_EG9)
An Air/fuel meter hooked to a narrowband (stock) signal is useless and will give you nothing more than a light show. Get a Wideband O2.
