K24 w/K20 head question
I'm a newbie here but I'm doing a K swap in a 99 si .I have a K 24 engine from a 05' CRv and I got a RSX head from a base model automatic .I have two simple questions here 1st would I have needed a RSX- s head or can I use the same base model head?And would I have to change the cams in the head since it was an automatic?Please if anyone can give me advice it would be greatly appreciated.thanks
Unceasing Measure
Re: K24 w/K20 head question (Juniorhatch)
Don't bother swapping that base RSX head onto that block. The Type-S head is the awesome one: the base is utter ****. 40hp difference, 30 or more of which comes from the S-type head.
what cams are you putting in?
Make sure that they work with your head....
the base rsx head is the same as the ep3 head...
i think its called an A3
so make sure u check that your cams are made for the A3...
if not then you are going to have to get an A2 or A head...
check with the ppl at k20a.org
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Juniorhatch »</TD></TR><TR><TD CLASS="quote">Hey thanks dude.</TD></TR></TABLE>
No problem I did the K24 bottom end with a K20A2 head about two years ago. It's not that hard to do if you have it out of the car and the power increase is awesome. The EP/base-RSX head just plain sucks
cute little bastard
Re: K24 w/K20 head question (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Don't bother swapping that base RSX head onto that block. The Type-S head is the awesome one: the base is utter ****. 40hp difference, 30 or more of which comes from the S-type head.</TD></TR></TABLE>
x2. You'd be switching heads/internals and nothing will change really. Look into a K20A/A2 head
Re: K24 w/K20 head question (SkoundrelUSA)
while you have the setup out of the car...you should do your head work put some pistons n rods in and drop a type S or s2k oil pump in that bitch...but for your original question go with a type S head..
to learn everything youll need to know go to the link in my profile....you dont get the bullshit there that you get here on honda tech
No problem I did the K24 bottom end with a K20A2 head about two years ago. It's not that hard to do if you have it out of the car and the power increase is awesome. The EP/base-RSX head just plain sucks </TD></TR></TABLE>
out of curiosity, what type of numbers do you see from a k24xx block/k20a2 head?
