What do I need to do for this motor to fit in my car?
What do I need to to wire this engine up properly?
ok, so i have a 95 civic ex, and the motor is a d15z1 which I believe is the vx motor, I want to know what I need to do for this engine to work on my wiring harness, any help would be greatly appreciated.
Modified by avsrule414 at 1:13 AM 8/28/2006
Re: (v4lu3s)
anyone else? The only reason I posted this is because I dont have time to look through like 30 pages of **** to find an answer, so I was hoping someone would be kind enough to help me out
you would need to wire up teh egr system and wire up the wideband o2 sensor. I beleive the o2 sensor it self has 5 wires, rather than 4 wires, which slightly changes the pinouts.
as far as getting it into the car it will bolt in like stock. you need to get a civic manual with wiring diagrams and comapre teh vx to ex, and you will need to get teh egr control solenoid and wire that in, usually it is firewall mounted.
Re: (v4lu3s)
what if i took the header off my d16z6 and bolted it up to the d15z1? would that work, or would change the readings my ecu is getting for that engine? Im guessing that doing that would possibly make my car run like crap. how about the d16z6 ecu, can i use that on the d15z1 engine?
Re: (avsrule414)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by avsrule414 »</TD></TR><TR><TD CLASS="quote">what if i took the header off my d16z6 and bolted it up to the d15z1?</TD></TR></TABLE>
not a bad idea
not a bad idea
be professional
Re: What do I need to to wire this engine up properly? (avsrule414)
You don't run a P28 ECU with a D15Z1. VTEC-E is physically completely different from VTEC. If you actually enjoy running 1 intake valve until 4800RPM then go right ahead, but rather than halfassing this swap, I would recommend you spend the couple hundred dollars for a Z6 longblock. Or, if you have a good Z6 head, swap it onto the Z1 block.
duckmanEG
02-04-2005 12:05 PM
dremmel
02-17-2004 08:24 PM
navin
05-28-2003 05:32 PM
