Ls Vtec Question??????????
Im building an ls vtec and have a couple of questions
-Will my b16 timing belt work?
-Can i use the head stuts off of my b16?
-i have two oil pumps one is a b16 and the other is an ls, which one should i use
-i would also like to know i just got an ls block and the pistons say pr3 on the are those the stock pistons?
-And what is the best stuuf to use to clean a really dirty block?
Re: Ls Vtec Question?????????? (BrAiNdEaD247)
I've done an LS/VTEC before...and I hope I can help you with my answers. If anything is wrong, please correct me someone:
You will need to get a B18 timing belt because the deck sits a little higher...the block is taller.
I believe you could, but I cannot be certain. I recommend upgrading to ARP head studs while you are at it.
hmmm i found these:
https://honda-tech.com/zerothread?id=1212747
https://honda-tech.com/zerothread?id=1273706
PR3s are from the B16A (USDM)...hmmm
"pr3 are all usdm b16a's and 1st gen jdm b16a pistons"
reference http://g2ic.com/forums/showthread.php?t=104216
Body shop does the best (inner and outer) for pretty decent affordable price. I'm not sure what to use because I always bring it to the shop to clean out everything.
hmmm i found these:
hybridb18
02-18-2004 07:40 PM
ysrhatch
10-09-2001 07:25 AM
