whining noise, coming from timing belt area.
well today i changed my headgasket, i set everything tdc then took the head of changed the gasket put everything back on right did the tension with the timing belt, now its whining.. but when its fully warmed up it makes this humming noise like the belt is rubbing agaisnt something on, but when i drove it it makes a loud supercharger noise. help?
Re: whining noise, coming from timing belt area. (ekx4)
Do you have AC or PS? If so check those belts along with the alt. belt. See if you could change the pitch of the sound when you rev the motor. It might be that the tensioner is on to tight.
barryfaetheus
07-23-2011 09:47 PM
bam181
08-20-2006 05:16 AM
