Things to fix
Things to fix
My 94 Eg hatch has some problems and i need fixes for them...
The steering wheel has lost its horn buttons - no horn.
The Seat belts have too much slack..they limp around and dont retract
The rear seat is developing a tear along the right center seam
My glove box wont close unless i slam it super hard
The left front fender has a dent in it that i cant pop out
Rust in the rear wheel wells
Car shakes and rumbles when im on the breakes hard or 80mph +
carpet is streched and worn on spots fugly.
headliner and door pleather has some scratches, dings, and rips.
Passenger seat wont move forward from farthest back location.
blower has leaves in it
fans are LOUD as hell
centerconsole emergency break lever piece has nice big crack cutting it in 1/2.
(considering pokom arm rest to replace)
Cig lighter socket doesnt work (but ash trey light does)
Climate controll lights dont come on somtimes (they still work)
Driver window rollup handle is really hard to turn 1/2 way window up
passenger door lock doesnt open from outside somtimes
back dash pannel is worn and about to break
back dash clips are MIA
rear trunk fabric is shrunk(i dunno how)
rear trunk cardord floor is bent
ac is warm (cooler than outside but not brrr cold)
rear view mirror moves out of place when i play music
side mirrors somtimes get pushed in twoards car by wind when on the highway.
Paint is starting to come off on side mirrors, and a small quarter sized spot above passenger side roof.
front bumper has a lose clip on passenger front side(it hangs down on the passenger end by like 1/2 an inch)
Winshield wiper fluid nozzles spray funky..somtimes OVER the car and somtimes of to the side onto other peoples car.
Rear wiper blade needs t be replaced
rear spray nozzle doesnt work
car lost torque when i replaced the air filter
suspention squeaks when i turn right hard or make the car bounce
front winshield has a nice little crack thats growing
my rear glass lost its hydrolics, i need new ones.
The plastic infornt of my guages is spiderwebbed (scratchey)
engine makes a little crunch noise when i start it up.
um....thats all i can think of right now....there might be more....i dunno. till...i <3 my baby.
Re: Things to fix (slowSOHCvtec)
I don't even know were to begin!! Forget about the cosmetic things right know it sounds like you need to focus on the mechanical things first. Get the front end squared away. Replace worn out ball joints upper and lower, inner and outer tie rods, and over hall the brakes put new rotors calipers and pads on. then get the car aligned. See how she drives and get back to us
Re: Things to fix (SkorchedAsh)
rear windshield wiper needs replaced
Re: Things to fix (Ricey McRicerton)
Steering wheel, its not about a fuse...the actual buttons came off in a fit of highway road rage BEEP BEEP SNAP o_o.....
Glove box - nothing is obstructing the latch, the glove box is empty and all the parts run like bitter, its funky.
Rotors - tires : so if i were to get new breaks/rotors and rims/tires it would most likley be fixed?
Passenger seat - i cant really see if theres anything there. Il have tounbolt the seat and mess with it then?
Fans - i cleaned it, but its still loud.
Window - how would i fix this? take off the door pannel and bend it back?
Crunch noise - when i start it it makes the start noise dadada vroom and in between the last dada and the vroom it makes an awful CRUNCH exactly like it souns CRUNCH like grinding metal...its awful.
I know others will eventually have these problems as well..it might help somone other than me...u never know.
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkorchedAsh »</TD></TR><TR><TD CLASS="quote">Crunch noise - when i start it it makes the start noise dadada vroom and in between the last dada and the vroom it makes an awful CRUNCH exactly like it souns CRUNCH like grinding metal...its awful.</TD></TR></TABLE>
Sounds like VTaK might be eating your flywheel...
But seriously, nice try with the description. I would take it to a mechanic if you think it will make it that far. And how much did you pay for that piece?
buy a bicycle horn and leave it near your center console. when you need it, just roll your windows down and horn.
go takata =]
thank god for duct tape
a couple of velcro should do
put a sticker over it. i think it adds 15hp yo!!11
a bottle of spraypaint from a dollar store should do
that my friend is your abs and you need balancing.
flip it over
good ol' dollar store paint
just tell your passengers to either grow taller or get shorter hehe
then your blow-er must suck ;D
thats a good thing. just tell your friends, "you hear that? thats my new turbo!!"
stick a pillow around there
smokers are for jokers. you dont need one
get a portable fan with a power inverter and stick it in the cig lighter socket
work them muscles. theres always a local gym right down the street
roll your window down just enough for your hands to get thru
duct tape is the solution!!
leave it. no one cares bout that. except maybe the passengers =P
go to michaels and fabricate it yourself
throw alot of junk in that trunk and just cover it up
crack them windows! boy!
ghetto that mirror and stick tape on it til it holds
stick something right in the middle of the gaps
spraypaint!!
cable ties !!
LOL!! as long as it works...unlike some stuff around your car ;D
do it!
you dont need it
thats why you only go k&n
thats what happens when you get ebay stuff
hmm, at auto stores they sell these things that fixes those
sheesh! your car is crappy enough. is it really necessary?
if its on the inside, and you see that spider go on your techometer, floor that b!tch and make that meter stick kill it =] if its still not that, rev it a couple times to make the stick go up and down until its dead
turn up the music. problem solved.
go takata =]
flip it over
spraypaint!!
cable ties !!
do it!
you dont need it
Re: Things to fix (pli)
lol...im trying to make my car less ghetto, and duct tape and spray paint wont help. And one big thing u got bad wrong was the cig lighter, the socket doent work for ANYTHING, not even a charger for my psp or ipod. ....and for those who asked, its the old family ride, bought new in 93(94 model year) and gifted to me at hs graduation in june.My baby<3
90civichb
12-11-2002 06:25 AM
