Can someone verify this information
I have a 92 DX hatchback that soon will have a D16Z6 engine from a 93 SI that I have. Since I will be using the engine harness that came with the D16Z6, will this harness plug to the harness on the 92 DX? and will the Vtec work or I still have to run some wires from the engine bay to the computer in order to have the vtec working. by the way I will be using the P28 computer from the SI as well.
H-T Poker champion
Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">using the si harness motor and ecu, you have a plug and play swap. your 92 is infact prewired for vtec from the strut tower harness to the ecu. </TD></TR></TABLE>
The SI and VX both came wired for vtec from the factory. I believe those are the only hatch models for the 92-95 civic generation that came that way.
Re: (Hatchy-Ownzjo0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 »</TD></TR><TR><TD CLASS="quote">
The SI and VX both came wired for vtec from the factory. I believe those are the only hatch models for the 92-95 civic generation that came that way.</TD></TR></TABLE>
Untrue I had a 92 Cx that was wired for vtec from the ecu to the first engine plug.
Re: (DeadEnd9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">every 92 civics were prewired for VTEC, for the record</TD></TR></TABLE>
exactly right.
exactly right.
HT Order of Merit
Re: (Boricuanology)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deckster333 »</TD></TR><TR><TD CLASS="quote">every trim in 1992.
After that I think they decided it would save money to not bother to wire for vtec unless it needed it.</TD></TR></TABLE>
This applys only to 1992.
