turn up boost or not?
well guys considering i'm now a boost junkie lol...i wana turn up my boost....basically i have a stock b18b and i'm running:
stock map sensor
garrett t3/t4 57 trim 60/63AR's
blaast performance log style manifold
TiAl 38mm external gate with a 10lb spring..
i just wana know if it opinions on it being safe to turn it up to 13psi ?
stock map sensor
Re: turn up boost or not? (slammed_coupe)
i've seen 13 psi on a stock block B16. Make sure you have a real fuel management system and real tune before you try anything.
Re: turn up boost or not? (G2 Speed)
yea well...the only thing that would stop me is my injectors...i'm running dsm 450's and a chiped ECU tuned with CROME...
boost is all in the tune. Someone could run 8psi and have no tune or a shitty tune and screw the motor up not long down the road. Another person could have hondata and have a dyno tune by a good local tuner and run 15psi perfectly fine.
Re: turn up boost or not? (shepworldwide)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shepworldwide »</TD></TR><TR><TD CLASS="quote">you know you really don't care what we think cuz your gonna turn it up anyways. so just do it and tell us what 3 more lbs did for you </TD></TR></TABLE>
thats true , even if we told you it was a bad idea you syill will turn it up just to see what would happen . my advise is to turn it up buand you shouldnt wory about messing things up with only 13lbs i saw this weekend at nopi guys running low 12s with stock motor
accord_raffi
Engine Management and Tuning
14
06-19-2009 06:13 PM
