need help solid check engine light
i have a 92 civic cx with a 94 gsr swap with uberdata, i had the same swap in another hatch but ended up sellin the car and keepin the swap to put in my new 92 hatch
i rebuilt the motor and it took bout a month and a half, now that its in i try to start the car and it just floods out the motor and throughs a solid check engine light. i tried a new ecu a stock p28 which runs perfectly in other cars but in mine it still throughs a solid check engine light.
any help would be much appreciated
Re: need help solid check engine light (batch)
get the code read and look in the "ecu codes FAQ" at the top of this forum
without that we have NO CLUE AT ALL
so ive read that a solid is a zero and means bad ecu but if i have tried 3 different ecus now which i know 2 at least are good wat does this mean and how do i fix it
Re: (AddictiveAllMotor)
i jumped it i have a switch wired to the plug switch on or off just solid and i cut the switch out thinkin maybe that could be the problem and just straight connected the wires but still no luck just solid light
Re: (batch)
the car ran perfectly when i was just a cx passed emissions and everything then i pulled the cx motor and let it sit for bout a month and half then put the gsr in
Re: (batch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batch »</TD></TR><TR><TD CLASS="quote">so noone has ever had this problem
guess noone here is really a honda tech</TD></TR></TABLE>
were just people like you, honda tech is the name of the forum
we are trying to help to the best of our knowledge, someone may chime in later that has the answer to everything, just be patient
Re: (batch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">It's solid because there is a problem. You have to do the neat-o trick with the paper clip to get it to flash. Do some research. </TD></TR></TABLE>
reading owns you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batch »</TD></TR><TR><TD CLASS="quote">i jumped it i have a switch wired to the plug switch on or off just solid and i cut the switch out thinkin maybe that could be the problem and just straight connected the wires but still no luck just solid light </TD></TR></TABLE>
reading owns you
Ek Forever y0!
Re: (93cb7sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93cb7sedan »</TD></TR><TR><TD CLASS="quote">
reading owns you
k, bye.
reading owns you
k, bye.
Re: (ek forever guy)
lol hahaha he said he knows how to get it to flash.. sometimes it just doesn't...
i had two codes b4... i just left the paper clip in there... when i installed my blue box it went away and left a solid light... my friend said my lil paper clip fell off... i told him it didn't... when my car had another problem there she was.. that blinking light...
Re: (93cb7sedan)
my bad didnt mean to start anything just really frustrated with this whole project this is my daily driver so i need to get it to run quickly
Re: (batch)
wait wait, you left your paper clip in, so you LEFT it jumped off.
you arent supposed to do that. you only jump it to get the codes then remove the jumper (in this case the paper clip)
im not sure if that would cause any issues, but ive been told do NOT start the car with it jumped. just an fyi
Re: (93cb7sedan)
i don't really know, a friend of mine who has been through turbo told me to leave it in... i thought it ran better... atleast till i get the problems fixed. i drove it like that for probably 4 weeks. idunno...
MattsGreenEG
03-19-2008 09:21 PM
