Neutral to D4 - Trans/Gas problem
~HELP~ Neutral to D4 - Trans/Gas problem
Hello, i recently bought a 93 civic hatchback dx. It was working fine and a little bit later last night i put it into neutral and then drive to burn out i guess you could say and nothing messed up. However later i guess after this when i turn the car on and drive up the street and its probably in 1st gear and then on its way to the next gear it sounds like *nnnnnnnn* and it doesnt catch gear and is like its in neutral for a few seconds (it acts as if i let go of the gas and it slows down for a few seconds and then it shifts up. So im guessing something is wrong with the transmission maybe it didnt catch the gear right when i threw it from N to D so idk? Anyone?
Modified by Steven Poljak at 5:20 PM 8/28/2006
Re: (Steven Poljak)
wow that is one of the most retarded things you can do! say goodbye to your trans if you keep doing that, or by the way your describing it, say goodbye to it now...good luck!
