wiper lever
wiper lever
how difficult would it be to replace the windshield wiper lever on a 94 dx coupe because i let my gf borrow my car and she tried to turn on the wipers by pulling down on it but she damaged the lever so now when ever i hit a bump the lever drops and the wipers turn on i think it has a broken spring so for now i have a bottle cap to hold the lever up and yes the wipers do still work
Re: wiper lever
Disconnect battery, remove airbag, remove steering wheel, then it should be two screws and the plugs and the lever/assembly will come out. Get a new/ used switch, and a new/used girlfriend.
Re: wiper lever
H-T White Ops
Re: wiper lever
If you turn the wheel, you don't have to remove the airbag.
Remove the column shroud. Turn the wheel so you can see the two screws. Remove the screws. Unplug the switch (it might feel stuck when you try to remove the switch from the column).
Re: wiper lever
$65 new: http://www.hondapartscheap.com/south...t=0&quantity=0
About half that price used: http://www.car-part.com/ or if your close enough http://www.picknpull.com/default.aspx
TegoDC5
12-15-2004 05:53 PM
